Question about Watches
Casio calculator watch, have changed the battery, the watch screen has come on but will not respond to any of the buttons. have removed the battery and refitted but still no response to the keys.
  • 1 more comment
  • edwardm515 Jan 13, 2009
    I have removed the board out of the watch casing and pressed the buttons but there is still no change to the display, so it is not keypad issue. The power is clearly on to the watch but i am not getting any response to the buttons on the side or the keys, its not blinking the time its just on displaying AM 12:00 02
    The watch could be over 10 years old.
    From looking up the casio website it appears to need a specific restart technique.
  • Anonymous Mar 20, 2014
    Bought it used, put in new battery, screen says "OPEN".buttons do not respond???
    Genius:
  • 2,920 Answers
How long did it go without a good battery in it/ before you changed it out?
Posted on Jan 13, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, Remove the battery. Short the positive and negative terminals in the watch. Hold it for few seconds.
Re-insert the battery and check if it works. Also make sure that the buttons are not stuck (always pressed).
If it still doesnt work, the watch is faulty.
  • 82 Answers
It appears it may have gotten wet or damp. when electronics get wet the best thing to do is take out batteries and put them in a bag of rice. the rice is very dry and will absorb the moisture out of anything this works well with cell phones as wellI know ive done it many times to the same cellphone although it may be too late for your watch. it probably is shorted out. thanks for using fixya!
  • 4,472 Answers
A bad electrical connection in the watch itself is most likely the result. How long have you owned the watch. How long have you had this problem? Once I have more information I will be more then happy to assist you further, also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • 535 Answers
Chak the key pad of your wach its fitting correctly or chak for loose connaction
  • sandip panchal
    sandip panchal Jan 13, 2009
    chak the capcitor its has been short
My watch Casio buttons has stopped working, what is the problem.
Hi
What Casio model is it?
Do you still have a bright display?
Have you tried removing the battery to reset it?
In some Casio watches like the Protrek range the back light button fails to activate the display light. This is sometimes caused because the earth flange that completes the circuit when pressed has bended to far or snapped and fails to complete the circuit.
More info about the watch may help find a solution. mean time change the battery it may start working again. Good luck
Feb 12, 2017 | Casio Watches
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
Thank you for contacting FixYa.
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How to restart my casio module no 2271 watch
    mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
    Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
    How to change the battery in a CASIO CA53W-1 Watch with Calculator
    open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
    there is a spring inside that goes betweeen one of the contact holes. dont know which.
    Jun 03, 2010 | Casio Watches
    Casio 1170 ATC-1200 watch needs to have batteries changed
    I'll post in case somebody still needs this. This is the general procedure to switch the ATC 1200 from meters to feet. You can also switch the ATC 1200 (1170) from C to F. This is very helpful if you change the batteries and the watch gets reset to meters.
    Also note, when you pull out the two batteries, you may not get the watch to come up. This is because of a race condition when the watch gets power. To fix this, look for the AC mark on the inside of the watch. Under this marking, in a little space to the left, are two copper pads. Short this out with a small screw driver to get the watch to ground zero.
    To fix the Metric measurements:
    1. Go to the home screen on the watch. This is when the the 3 letter abbr for the day is at the top. Also, if you cycle the mode button, it is the screen where the final beep is "high."
    2. Then press the "memory" button, which will take the home display to the data screen. This shows current time, pressure and temperature.
    3. Hold down the adjust button, until the set screen comes up.
    4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
    You can adjust all the measurements from this screen.
    Jan 10, 2010 | Casio Watches
    6 year old Casio no. 2271 has ceased responding to buttons
    Hi, If you buy some new batteries - i.e. from ebay (very cheap) and replace the old ones - or take tyhe watch into a jewellers and get them replaced (appx. £15) this should do the trick. The batteries should be replaced every 2 years.
    Jan 02, 2009 | Casio PRG-40T-7 Pathfinder
    Casio Databank watch
    The replacement battery may be defective.
    Nov 08, 2017 | Casio E-DataBank DBC3101 Wrist Watch
    Watches Logo
    85 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
