Question about Craftsman Garden
Why dose the blades keep turning when mower is disengaged
  • Craftsman Master
  • 2,239 Answers
If the machine has a manual blade engagment, there is normally a small brake block that presses against the upper blade pulleys to slow and stop them, these may need replacing, if not then the drive belt may be dragging in the pulleys
Posted on Dec 11, 2012
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
  • 636 Answers
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
Posted on Aug 15, 2009
braintrust
  • 62 Answers
SOURCE: after replacing the belt, new pulleys, and bolts,
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Posted on Oct 27, 2009
Mower will start fine when I engage the blades it will mow for a short time then the mower wants to stall and will if I don't disengage the blades
Are the blades turning freely when disengaged. Is it possible something is interfering and binding them somewhat (for example, if the mower picked up some rope and it wrapped around the shaft to the blades)?
Apr 02, 2016 | Garden
Blades keep running in all gears on my mtd 420/38
Assuming you have put the blade drive lever into 'disengage' check the blade drive belt tension. With blade disengaged, belt should have significant slack. You may need to adjust the control cable, adjustment is usually on the mower deck; or you may have some debris on the deck preventing the pully to release belt tension
Jun 26, 2014 | Garden
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
I have a poulan pro PR1842STC; the blades won't stop turning after I disengage the mower belt
On the top of the mower deck, there is a spring that will pull to disengage the blade idler pulley. At the same time, it will release two springloaded arms with brakes that press on the pulleys at the top of the blade spindles. On top of the mower deck at the back, the two spring loaded arms may be held out of the braking position by a cam. Make sure the cam is free to allow the blade brakes to activate when you disengage the blades. If arms are out of alignment, or the parts are too worn, the blade brakes won't move and the blades keep spinning, even after you have disengaged and the safety switch is deactivated. This is a dangerous situation and should be fixed soon. Good luck.
May 09, 2013 | Poulan Garden
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 | Garden
I cannot disengage the cutting attachment so that the mower will start; it seems like it is stuck, because when I attempt to disengage the blades the lever will not move into the disengaged position. How...
You haven't specified the model number, but pretty much all riding mowers use a plunger-type electrical switch to engage the mower. If it's stuck in the 'lifted' position (mower engaged) then it has broken internally. You must replace it. In doing that, the wires need to be placed back on the correct terminals, so take a picture of the wires (showing their colors) before you disconnect them from the switch. Take the broken switch to a lawnmower shop to find a replacement. Shouldn't be more than $10 - $20. Good luck! Please rate my solution if you found it helpful.
Jul 03, 2010 | Craftsman Garden
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I finish mowing yard I disengage mower blades but they keep on turning why
If this mower has a manual lever that has to be pushed up in order to engage the blades then check the tension pulley that connects to the lever cable on the top of the deck,it probably need to be lubricated or cleaned in order to move freely back to the normal position.
May 14, 2010 | Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
My john deere riding mover the clutch will not disengage it still keep going.any solutions
With the engine OFF, reach underneath and locate the plug for the blade clutch and unplug it. Start up the mower and see if the blades are turning. If they are still turning with the clutch unplugged, REPLACE THE CLUTCH
Jul 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
388 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
