Question about GE GFDN110ELWW Dryer
GE GFDS350ELOWW won't power on
IS new, never used
    President:
  • GE Master
  • 1,922 Answers
Your fuseable safety thermostat mounted on the rear inner wall of the unit open,on a GE these fuses open and it kills the whole units power its under the top cover and to the 2:00 position of the heating element,but if its new call for warranty service it shouldn't cost you anything if its under a year old
Posted on Dec 11, 2012
My Dishwasher won't start unless I push firmly on the door.
Change the handle there is a switch on the handle that activates when the door is closed the switch is broken you have to buy the whole handle not just the switch
Apr 11, 2013 | GE Dishwashers
Replaced power cord, now dryer g.e. DRSR495EG8WW won't work
There is a thermal fuse on top of element housing.
Nov 08, 2017 | GE Dryers
Ge Washer won't start, lights come on but won't stay on, what do I do?
Go online and search for brand and model number service manual. There are probably multiple things it could be, but the troubleshooting section should point you in the rite way.
May 30, 2012 | GE Washing Machines
Ge gas oven ran self clean door won't unlock door locked flashing lock motor running continuously
if your motor is running continuously, the door is locking and unlocking. catch it when unlocked, and unplug the range. then disconnect the power wires from the lock motor. this will allow you to use the oven while you get a new lock assembly and replace the one you have. should be fine after that.
Feb 04, 2012 | GE 25 in. GSC3200GWW Free-standing...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
    Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
    Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
    Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    Need electrical cord for general electric skillet
    Call this number: 877-207-0923. You will be able to order the replacement part.
    Nov 22, 2008 | GE 106749
    GE GFDN110ELWW Dryer Logo
    150 people viewed this question
    Top GE Dryers Experts
    Dave Harrison
    John Tripp
    John Tripp
    vince
    Are you a GE Dryer Expert? Answer questions, earn points and help others
