Question about Sharp Mx-2310u Color Copy/print/scan
Documents in printer que, but does not print - Sharp Mx-2310u Color Copy/print/scan
  • 1,684 Answers
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Posted on Feb 15, 2013
HP 1300 LASER JET PRINTER KEEP REPEAT PRINTING
It sounds like you have unprinted documents in your print que that need to be cleaned out. click on the arrow on the bottom right side of your screen next to your clock in order to view it. find the picture of the printer and right click with the button on the right side of your mouse on top of it. Open the print que and choose all printers. If you see documents in this area, click on them one by one and delete them. After they are all gone, close the print que and try printing something. this should solve your issue.
Apr 30, 2012 | HP LaserJet 1300 Printer
I want to clear the que. I tried to print a page and it will not print. It has remained in que for two days. I have tried to cancel it, didnt work. I unplugged the printer and usb cable, it still did...
If you are using windows operating system than go to Printer and Faxes, Double click on the printer icon. A window with printing document que will appear, click on "Printer" and select "cancel all documents" and then switch off the printer for few minutes. the document que will disappear.
Aug 12, 2011 | Lexmark X5650 All-in-One InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
I cannot cancel the commands given preiously it just shows 'Printing' but never prints, what do i do?
Open the printer (click on the taskbar). It will list the documents in the print que. Highlight each one and delete it.
Now the printer has not documents in the que and should start fresh!.
-Jim
Oct 23, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
I attempted to print a 25 page document, with reverse pages. Only 9 pages printed. I cannot print anything now. and the message on the printer reads, DATA REMAINING. I have pushed every button...
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Apr 14, 2009 | Brother Office Equipment & Supplies
Need Dell All-in-One printer 924 to work with Inspiron 530S.
If it doesn't say it is specifically for VISTA then it is not for VISTA.. Even if it does show up on the computer ,that just shows that some driver for that model printer is installed. Not necessary one that will work. Go to the weblink that I gave you. Download the VISTA drive and update the driver, using the one you downloaded ,and that will most lkely fix the problem.
Mar 03, 2009 | Dell 924 All-in-One InkJet Printer
Can not delete document in print q - nothing else will print
Open task manager,(Ctrl +Alt +delete) and end task on print spooler,delete the file.print spooler will restart automatically.
This works best if you have the que window open first.
Please rate this fixya
Jan 25, 2009 | Lexmark X3550 All-In-One Printer
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Document locked in que
Solution #1 Have you tried to power off the computer itself? The document is most likely locked in the PC not the printer. Unplug the printer's power, power down the computer, wait a minute or so then restart the computer. Once the machine has loaded check the print queue to verify the document is no longer there, if so you can plug the printer back in and the issue should be resolved.
Solution #2
From the Start menu, select Control Panel. Then follow this path:
Administrative Tools > Services > Print Spooler
Once at the Print Spooler, right click on it. Select Stop. Leave this window open. Turn off your printer.
At the open Print Spooler window, right click on the Print Spooler, and select Start.
Go to the Start menu, and select Printers & Faxes. Find the printer you are having problems with and double click on it. From the menu, select Printer, then select Cancel All Documents. The documents should clear.
Turn on your printer. You sould now be able to print.
Oct 15, 2008 | HP PSC 1350 All-In-One Thermal Printer
Sharp Mx-2310u Color Copy/print/scan Logo
416 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
