Question about Cycling
Schwinn XR8 scraping/squeaking noise on stationary bike
Lubed everything but intermittant high pitched squeak is still present. Any ideas? I have written to Schwinn Customer Service and am awaiting their response.
3 Suggested Answers
  • 603 Answers
SOURCE: Scraping/Squeaking noise on recumbent stationary bicycle
There are most likely some sort of bearings inside the wheel hub that are causing this.
Posted on Jan 14, 2010
  • 456 Answers
SOURCE: My pedals are squeaking while pedaling on my
hi.
i cannot see any problems with wd40 on any bike and have used it myself for many years.
just wipe away any excess, and do not spray it on the pedal tops (where your shoes go) as they may get slippery.
light oil (3in1 or simillar) is also excellent on bikes instead of wd40. same advice as above.
i find wd40 works faster, especially on squeaks, but oil works for longer.
i usually use wd40 first to cure the imediate noise, and then use a few drops of the oil to keep it quiet for longer.
hope this helps
Posted on Apr 24, 2011
Troubleshooting a problem with high pitched squeaking in GE dryer model PBVH520EJ0WW Squeaks when load is small or nearly dry - repairman came to check it out and said he 'couldn't fi
Could be the bearings going, other possibilities could be that the drum is slightly misaligned and scraping against the housing, although that's not very likely, or a bad belt.
Although sometimes it's some obscure thing, I could be compleatly wrong.
Oct 01, 2014 | Dryers
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
Help safety device has activated brother innovis 750e
could be a broken or damaged part, could be a timing problem, it would be a good idea to have the machine checked.
Jan 28, 2014 | Sewing Machines
High pitched squeaking dryer
its just the bearing and it needs replaced. it will take about two hours to do and it will cost you about 30 dollars in parts. you can find many really goods vids on youtube that will show you how to do it and most parts manufactures now have directions on how to do it in the cluded when you buy the parts.
May 09, 2013 | Dryers
My GEM GL-1821A Computer monitor has a high pitch squeak that is intermittent in occurrence but sometimes continues for long periods of time. Got any ideas?
A high-pitch squeal is common in CRT TV sets and monitors. I've never run across this in an LCD monitor, but there's a first time for everything. If the sound isn't coming through built-in speakers (if this model has them) and is being caused by the computer, I would suspect the inverter circuitry. This provides power for the backlight, and there are transformers that may have become noisy. Because of their construction, it's possible for them to vibrate internally, and at a frequency that you hear as the high-pitched noise. There isn't a lot you can do to quiet them. When I worked on TV sets, I had mixed success using hot-melt glue to muffle the noise, but usually the only way to completely cure the problem was to replace the parts. It's unlikely you'll find the parts available for a monitor, so all I can suggest is to bear with the noise as long as the monitor is otherwise working properly. Or use this as an excuse to buy a new LCD monitor; they are quite reasonably priced these days.
Feb 16, 2011 | Think Computer GEM 15 Inch LCD BLACK...
Dryer makes a high pitch squeaking noise
This could be a dry support bearing, a dried out drum seal or something stuck in the drum seal. If I could hear it I would know better where to start. Listen and try to locate the source from the above list. It could be the belt but that is not as common.
Eric
May 20, 2010 | Dryers
Jan 13, 2010 | Cycling
2006 Saturn Vue squeaking when I turn the wheel R or L
That sounds like a power steering issue. Does it make the sound when the car is stationary?
Jul 11, 2009 | 2003 Saturn L-Series
Scraping/high pitched noise in GE model DCVH515GFOWW.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sfdyjsdf
Mar 03, 2009 | GE DCVH515GF Gas Dryer
Cycling Logo
218 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
