Question about Refrigerators
How do I to remove cover for cold water tube in refrigerator side?
    Problem Solver:
  • 9 Answers
Need more information like Make/ Model. Are you trying to replace water tank or filter housing?
Why do you need to remove the waterline from the refrigerator side?
Posted on Dec 10, 2012
CremeStout
  • 115 Answers
SOURCE: kenmore side by side refrigerator
If you got a parts manual for your Kenmore the Illustrated Parts breakdown will usually show how to access the hardware.
(I would think you have to remove the inside shelf assembly to get access to screws).
How ever search the web for your kenmore model number, alot of places sell replacement parts and you can get an idea how to replace by looking at the sequence of "IPB", shown at some of these web sites.
Posted on Dec 03, 2007
SOURCE: whirpool refrigerator ,water dips into the fridge compartment from the freezer
drain tube location on Whirlpool frig??
Posted on Jan 23, 2009
Sea Breeze
  • 4655 Answers
SOURCE: KitchenAid Refrigerator water tube needs replacing
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Please send me your model number so I can give you better instructions. Clorox in the water supply and waiting until the Clorox is cleared from water dispenser and Ice will also do the job!
Posted on Apr 04, 2009
milten1
  • 1304 Answers
SOURCE: connect water line do i have to open the back cover
if you reamove the back you should see a preassembled water line stuck back there
slide it out ansd into the cannel
Posted on Oct 03, 2009
  • 401 Answers
SOURCE: Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
Posted on Jan 12, 2010
Water accumulates in the freezer tray turning to ice & flows to the floor if ice not removed in time.
there is a drain tube along the back inside of freezer side that clogs up with ice use hot water to melt ,and you may have to remove rear cover in back to remove the drain tube on right side to clear it .
Mar 16, 2015 | Whirlpool GB2FHDXWS Bottom Freezer...
What's your problem?vent on inside covered with ice. not cooling properly
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 20, 2011 | Roper RS25AEXLQ Side by Side Refrigerator
I get a small puddle of water in front of frig, about once every 2 or 3 weeks
THe defrost siphon tube in freezer is partly blocked. Turn off fridge, remove cover of condenser and check the drain tube for blockage.
Nov 08, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
How to clean/pull out reservoir in bottom of fridge?
If the instructions are different than below,I will need you model number. Water Tank Assembly (some models)
1. Remove crisper drawers from fresh food compartment.
2. Remove hex screw holding water tank to rear
bulkhead.
3. On rear of cabinent remove hex screws holding water
valve cover plate.
4. Remove plate and tubing away from cabinet to expose
water valves and tubing.
5. Disconnect water tube from secondary valve coming
from water tank, remove compression nut from tubing.
6. On front of unit remove toe grill and disconnect water
coupler going to water dispenser
7. Remove compression nut from water tubing on cabinet
side of connection.
8. From rear of cabinet pull water tube out of conduit
going to dispenser.
9. From inside of fresh food compartment pull tubing up
and out of cabinet to complete removal of water tank.
10. Reverse procedure to reassemble.
To clean I would use Clorox and warm water and rinse well before replacing. Thanks, Sea Breeze
Apr 18, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Jan 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
There is water building up inside of the freezer at the bottom and freezing. Some of it leaked out the front onto the floor. The water hoses are all intact and well connected. The refrigerator fan comes on...
Clean the drain tray and drain line in the back of the freezer section, located behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Jan 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water comes out of my frig door dispensor but its not cold?
on most all refrigerators the 1st 2 glasses of water may only be room temperature because of the way the water tubing is routed thru the refrig. if you will notice on your dispenser cover it does not say chilled or ice water. thanks for using  FixYa Peyton
Feb 17, 2009 | Frigidaire FRS266ZDSB Side by Side...
Refridgerater
It could be the defrost thermostat located on the condenser coil on the left side of the fan in the freezer compartment... or else it could be the defrost timer located in the refrigerator behind the dome cover... defrost the freezer and make sure the drain tube is not blocked nor the air passage which blow cold air from freezer to refrigerator compartment below. Water should drip from freezer down hole into tube to an evaporator pan on the top of the compressor near the floor in the back. Make sure the tube is free flowing by pouring some hot water down it before restarting refrigerator. Rarely the defrost heating element shorts, but a simple continuity test will determine if that is o.k. Make sure the refrigerator is uplugged before checking any of these areas... there's 120 volts all about and with water and ice it can cause quite a jolt!
Oct 05, 2008 | Roper RT14DKX Top Freezer Refrigerator
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Disconnect water line at door
press on the collar of the assembly where the water tube enters the coupler with your thumb. The pressure of your thumb should allow you to remove the water supply tube.
Mar 22, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
