External speakers don't work
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If the set has a connection for external speakers they have be the same impedance (ohms) and the set will likely have to be switched from internal to external.
Posted on Dec 10, 2012
Samsung UN60ES8000 internal speakers don't work
The speakers may have been turned off at the time of initial setup, especially if you planned to use external audio
Mar 17, 2013 | Samsung UN60ES8000 60" 1080p LED 3D TV...
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
How to connect a samsung soundbar to my tv and sat and dvd
Feed the audio from the audio out on your tv to the receiver. Plug your sound bar into the speaker output of the receiver and you should be up and running. You will have to turn on the receiver and control the audio there. The TV may have a setting for external speakers that you need to turn on in the audio menu. Now this is the straight forward approach but there are many factors to consider. One example would be the amplifier output being compatible with your speaker so you don't blow the speaker or the amp or amp/receiver combo.
Sep 28, 2012 | Samsung Hw-e450 Air Track Soundbar
Hooked up a cd player to my 2005moms grand am but volume don't work? Why?
Check to make sure it is not manually muted, if that doesn't work make sure your speaker wires are connected properly in the back of the radio and speakers work also. If it is run through an amplifier, make sure the amp works and the speaker wires are connected properly too! Don't forget to check gain on the amp too!
Jan 16, 2012 | JVC Car Audio & Video
How to connect my old wharfedale speakers to my led tv, bare wire type
you may have to connect them through an external amp using analog audio out on tv, these don't have speaker jacks for direct connection........Regards, Meder's Tv Service
Oct 06, 2011 | Televison & Video
I've problem with interanal speakers in Asus VX2S - don't work - externals work fine
It might be a cause of Loose connection or damage of your laptop speakers. Its a hardware problem. Check your Connectivity of Speakers on the motherboard. It might work!
Sep 01, 2011 | ASUS Lamborghini VX2S-B1Y Notebook
Well I've bought the new Ibanez AF-2, and when I plugged into the FX Loop of my Peavey 5150 combo and tested the TakeOff mode, my amp for a bit don't blast my head off and destroyed the...
You put the pedal where???? The guitar goes through the pedal. This is NOT to be used in an external effects loop of an amp. The signal levels are wrong as the effects loop is LINE LEVEL and the pedal is for instrument signal levels. Move the pedal to before the inout of your amp as it is designed to be used.
Jul 19, 2011 | Ibanez AF2 Paul Gilbert Signature Airplane...
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
How do I turn tape monitoring on my Denon AVR 3803 on/off? I recently purchased a set of Series V Bose 901's and I am having a difficult time figuring out how to activate the equalizer.
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Oh, but you don't have pre-outs. Bummer. Most AVR's will NOT pass digital sources to analog tape outs. Page 40 of the manual confirms that.
no can do. sorry. You need Pre-Outs to feed an external amp.
May 22, 2011 | Denon AVR-1803 Receiver
I have my amp and and subs hooked up right but i have multiple component wires on the back of my vm 9412. i need to know what to hook my component wires to in the back of my head unit and also need to know...
If you are running your speakers/subs from an external amp, then you wouldn't use any of the wires in the back. Usually you don't have any type of menu to change to make anything work. Some units have the ability to turn the signal off to the amp. What color are the wires in the back that you have remaining?
Apr 13, 2011 | Car Audio & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
