Question about Car Audio & Video
Where can I purchase a battery for a Kenwood TR-2400 2m FM Transceiver?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
If you are in the U.S. you can try pacparts.com.
Posted on Dec 11, 2012
Kenwood tr 9130
http://myradio.piczo.com/microphoneplugandsocketpinouts?c
states that the pinout is as follows.
I believe this is a semi standard connector that you can find at "some" radio shacks. If not you can take any Kenwood mic and soldier the wires to the old plug.
If you want a new connector try Mouser or Allied.
KENWOOD-TR9000-9030-9130-9300-9500-7700-7730-7750-7800-7850-7930-7950-8400
PIN1 MIC
PIN2 PTT
PIN3 DOWN
PIN6/CENTER EARTH
PIN4 UP
PIN5 NC + 8VOLT SOME MODELS
Jul 01, 2014 | Radio Communications
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Cb radio modulation
www.cbtricks.com
use the vr adjustment points to adjust the AMC modulation. DO NOT cut the mic audio limiter tr-32 or the modulation limiter tr-54. it will over-modulate and splatter out of band if you do
Feb 15, 2014 | Connex 3300, Deluxe Amateur Transceiver,...
I have a ubz-lh14 and all it does when switched on is beep every couple of seconds.
The Beep indicates low Batt. But if you charged the battery then clean the terminal connections on the battery and the radio. If still no good then you need a new Battery.
Aug 23, 2013 | Kenwood UBZ-LH14 FM transceiver FRS...
Cant program my kenwood tk480
Hi Manaf,
There is a solution to your query.
Join yahoo group SPECIFIC to your radio Make/Model, the people there will help you to get the required software, if available.
Joining is FREE and you can download manuals, schematics and software.
I hope this helps you to solve the problem.
Cheers,
Peter
Dec 31, 2012 | Kenwood Tk480 Fm Transceiver 800mhz Ltr...
Send me Kenwood TK-K2AT VHF FM Transceiver Manual
Here's a link to a free .pdf manual for your transciever.CLICK HERE
You can download it to read offline or print if you wish.
Dec 08, 2011 | Radio Communications
Kenwood 416s how can i plug in i pod
This model does not have an auxiliary input. The easiest way to hook up an external MP3 player, such as an iPod is with an FM transceiver.
Mar 04, 2011 | Kenwood KDC-416S CD Player
I need a belt clip of Kenwood TK-2160 vhf fm transceiver
Kenwood Part # is J29-0701-05 for the spring clip type. If you have a mailing address I'll send you one.
Apr 15, 2010 | Kenwood Radio Communications
Communication not good &battery cannot charge
If your area is big or has a lot of concrete, then you will need more then just a few cheap radios from thailand, Given range info from broshure is always meant above flat area - not inside building
Sep 23, 2009 | Motorola Walkie Talkie 2-Way Radio
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
