Question about RCA L32WD22 32 in. LCD HDTV
I have an RCA L32WD22 that has picture but no sound. It wasnt powering on so I changed some capacitors on the power board and now it powers on fine but no sound, so I ordered a new sound board and still no sound, all connections are snug, what could this be??
  • RCA Master
  • 933 Answers
Make sure your power supply outputs are all within tolerance. Second verify that mute isn't turned on. Next, check and see if your model gives you the option to turn off the internal audio. Some sets give you this option for those who want to use surround sounds.
Posted on Dec 10, 2012
  • 6 Answers
SOURCE: RCA L32WD22 TV with a bad power supply
The solution to your problem is to not buy this junk from Wal_mart in the first place. You won't find any replacement P.S. anywhere. This is consumer fraud from RCA, file a consumer fraud suit against RCA. The law says the manufacture must supply parts for at least 5 years from date of sale. Dan@DBS
Posted on Sep 06, 2009
budmrtn
  • 11361 Answers
SOURCE: my rca l32wd22 will not power up what do i do
First place to look is the main power supply module for simple thing like fuse, then look for 5V standby, you must have at least this standby voltage. This 5V (should always be there with the TV on or off) is supplied to the main board so when you turn on the TV, the main board will send the ON signal to the main power supply to supply voltages to other circuits.
Posted on Nov 03, 2009
  • 308 Answers
SOURCE: RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
Posted on Mar 10, 2010
  • 277 Answers
SOURCE: i have a rca l32wd22 screen weht black with no
Aboyd992,
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
Posted on Jul 21, 2010
  • 277 Answers
SOURCE: tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
RCA L32WD22 made popping noise, now no picture or sound
Power supply is most likely and only boards are sold, RCA is not always easy to get parts and tech assistance is almost zero
Dec 23, 2012 | RCA L32WD22 32 in. LCD HDTV
Rca flat screen; 32 inch; model # L32WD22; green power light comes on but no picture or sound
i think its from the cables try to put them correctly ... i think u putted them not in the good place
Jul 02, 2012 | RCA Televison & Video
When i turn my 32'' rca flat screen on the red light is flashing but it would not come on ,what is causing that to happen ?
Power Supply problem, had the same problem, could not find a Power Supply board replacement even on ebay. They had a capacitor replacement kit, here on ebay http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Used that, and it worked.
Dec 11, 2011 | RCA L32WD22 32 in. LCD HDTV
Our tv when itis on for a while some times the picture freezes an then goes blank an a loud hissing an squeech sound we have to unplug it to turn it off.
Hissing sound normally from Power Supply unit(PSU), usually from Transfomers in the PSU. Usually caused by bad capacitors. Try this capacitor replacement kit, on ebay only $15. http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Could not find any PSU board available at the moment, but have tried that kit and it works.
Nov 30, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a RCA L32WD22. When I push power on, the green light comes on then goes amber and the TV shuts off. Takes about 4 seconds and never get a picture.
I would resolder the inverter chips about five of those on the inverter board first. If that doesn't fix it, try the Power Supply unit (PSU), order this capacitors http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
or better if you can get a new PSU altogether, but doubt you can find one right now.
Oct 27, 2011 | RCA L32WD22 32 in. LCD HDTV
Tv wont turn on red light is flashing.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TVpower stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem, Take care.......
Sep 18, 2010 | RCA L32WD22 32 in. LCD HDTV
32 INCH RCA TV sound no picture
Check power supply to see if it is putting out the 24vdc needed by the backlight inverter board, you may have failed power supply or shorted out backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Aug 18, 2010 | RCA L32WD22 32 in. LCD HDTV
Mar 10, 2010 | RCA L32WD22 32 in. LCD HDTV
My L32WD22 doesn't seem to be getting any power.
tnbanderson,
Pls take your tv to a tv service center and ask them to fix it. They won't be able to. So you make sure the make a workorder. When you get that order, you call 1-877-297-8391 and they will give you a tv
Feb 03, 2010 | RCA L32WD22 32 in. LCD HDTV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 32 in. LCD HDTV Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
