Question about RCA P52937 52" Rear Projection Television
I have a bug behind my jvc flat screen tv
How to remove front panel and are the screws that are on the bottom , need to be taken out
    Champion:
  • 240 Answers
This is a very delicat job and menny screws i recomend sumone that has had expirence with lcd and plasma to do the job for you.
if you desid to do it your self be very caiful and remove all ribon cables to main pcb and power supply also cables to the inverter compleat disassembly to get to front of screen is required.
hope this helps you.
regards.
daniel.
Posted on Jan 13, 2009
How do I remove the screen from a JVC HD-61G787?
May I ask why you need to remove the screen? There are a lot of screws around the back and along the bottom of the front after the speaker grill is removed. you will have to unplug the control panel before you remove the screen assembly....tks
Nov 04, 2013 | JVC HD-61G787 61" Television
How to remove front screen from JVC flat screen
You have to disassemble as in whole to take apart the screen. It is really a skilled work. Just check this link and see whether there is any information about the disassembly process. It has disassembly procedure to many TVs, with illustrations.http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 02, 2013 | Televison & Video
AV-65WP84 when i connect video or the antenna the screen start to blink green does anyone knows about this problem on this jvc i-art tv?
Have someone open it from the front (front grill below screen is secured on either side at back with screws) and remove inspection plate behind grill--someone needs to locate the small black block with 6 adjustments and locate the green SCREEN not the green FOCUS and turn the green slightly down.
Care needs to be taken as set must be on--do not touch anything else inside as dangerous voltages are present when set is on.
Mar 16, 2012 | JVC Televison & Video
How remove the Sony Rear Projection TV KDS-R50XBR1
the lamp is located if you are standing in front of the tv, on thr right hand side behind the screen on the side of the tv there is a thumb screw that you have to remove with a flat head screwdriver then you can remove the door and see the lamp inside.
Oct 06, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Bug between screen and plastic cover screen how do i clean
You will have to remove Front cover in order to clean, remove bottom part then you should see screws holding on screen remove and clean
Sep 21, 2009 | JVC HD56G887 56" HDTV
Bug behind plastic screen cover and loose right side movement
Sadly the entire system needs to be taken apart. There is going to be at least 15 screws to remove and you need to move with surgical precision.
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 14, 2009 | HP Mini 1035NR Notebook
Red lines on screen
On the front down bottom there is a fake button hole cap pull it out and remove screw one on each side and you might have to remove back to undo 2 more screws inside TV. The screen/focus Block is behind it 3 controls on top 3 on bottom R-G-B Check Video IC on CRT board of Red Tube/ First try adjusting Red screen drive control .Let me know if need any help.
Jan 01, 2009 | Sony KP-57WV600 57" Rear Projection...
Screen went black
Remove the front grey bottom panel of you TV (don't forget the 2 screws behind the front AV cover located just below the power button) then remove the panel behind the grey panel. You should see 2 heat sinks on the front right of your TV, place a fan near your TV and have it blowing on the heat sinks. Now turn on your TV and see if it stays on longer then it has been. If it does, your DC amps might be overheating. If they are, you might be able to fix your problem by adding in a little more heat sink compound between your DC amps and the heat sink itself. You can find the compound at Radio Shack for about $5. let me know if pointing a fan directly on the heat sinks helps.
Jul 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Cleaning the inside of the front screen
It's not hard but is time consuming
You'll have to pull the front of the unit off to clean the inside. This includes taking out the screw that are open normally and there should be about 4 screws that are behind the bottom-back panel.
When you open the unit just be sure you get it clean the first time and don't leave any stray fingerprints on the glass. And don't touch the projection lens at all. Use compressed air to blow it off but I wouldn't recommend cleaning it unless it is just filthy and the canned air doesn't work for you.
Nov 19, 2007 | JVC HD-52G886 52" Rear Projection HDTV
RCA P52937 52" Rear Projection Television Logo
233 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
