Question about Cambridge Audio Audio Players & Recorders
Caimbridge audio amp right channel always dies
Hi All, I have a Cambridge audio 540a V2 amp and Tannoy V4 FS speakers. Music from the speaker connected to the right channel at intermittent times will begin to crackle a little bit... this will then progress to the music cutting out and back in again... and on some occasions the music dies in that speaker all together. On some occasions it will work fine for a whole day. I have tried all I can think of - by process of elmination Im certain its not - wires (speaker or computer) - speakers - computer/software or music format.. I dont think its power supply related as this set up worked for years in my house before i had any problems. I can only think that it must be something with the amp. I have also borrowed my friends completely different amp - and do not get any problems when I use that. The problem is that I have taken it back to the shop I bought it at now and they are saying they have tested it twice and cant detect the problem. Could anyone advise if it is likely to be the amp and if so any ideas on what is wrong with it? Transistor problem maybe? Thanks.
  • Cambridge Audio Master
  • 5,487 Answers
Stereo amps are two mono amps put together. So if you have a bad channel then you also have a good channel to compare it with. I suspect you have a faulty transistor. You can test it by proding the channels with a pen or your finger - touching plastic only parts. The two channels should buzz. If buzzs in the left then if you touch it in the right it should do the same. An alteration or change in the sound in the right and you have found the faulty part.
It's nothing to do with the power supply section so keep away from that!
Posted on Dec 16, 2012
megatronix
  • 57 Answers
SOURCE: Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
  • 4234 Answers
SOURCE: need manual for ra 840bx4 & wattage output when remote speakers?
Lets try the simple stuff first. This whole problem could be caused by a dirty switch contact. Pick up some electronics cleaner from a local electronics shop and spray the switch (from the inside of the unit). Work the switch on/off a number of times then respray one more time. That should clean out any dirt that is there. Try the unit again and hopefully the problem is resolved. If not, then the switch itself may need to be replaced. When you get the cleaner, get one that contains a lubricant as well. This will help to prevent the problem from coming back again.
Dan
Posted on Jun 22, 2009
SOURCE: no audio - Pioneer Amplifier A-Z370
I experienced something similar.
Symptom: After use the sound cuts out together with a mechanical click (relay sound). Turning off and waiting a bit before powering on, tends to 'fix' it, but the sound cuts out in the same way after a while.
The click led me to the little relay board inside. Inspection of the solder joints showed that a few were 'broken' ("cold soldered"). This was right below a high-wattage resistor, possibly the cause of the stress causing these random disconnects.
Fix: Resolder the joints.
Posted on Jun 30, 2009
  • 231 Answers
SOURCE: Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
Posted on Jul 21, 2009
  • 24 Answers
SOURCE: NAD 3020a crackle in right channel regardless of volume.
more than likely you have a bad transisitor on that side and the frequincey is distorted there's not much you can do except take it back if it's new or take it apart and check for the bad part but if you do that you had better know what your doing!! it may be just 12 volts but thru an amp it's a nasty shock
Posted on Jul 26, 2009
I have a red protection light flashing whenever i try to work my amp and i was just wondering what the solution is or how to reset it, thanks
Normally this means that the power supply or the load is incorrect.
Have you very low impedance speakers ?
Have you tried disconnecting speakers from amp and powering it on.
If it does and you do not get any protection light you need to investigate your speakers.
Feb 12, 2011 | Cambridge Audio Azur 540A Amplifier
I want to buy a trasformer for cambridge audio radio ammplifiare azur 540 v2
Cambridge Audio will be the only people that have spares
Check their website
Aug 26, 2010 | Cambridge Audio Azur 540A Amplifier
I have cambridge audio azur 640a amp. Problem I have is only the one speaker is working. Both speakers seem to be ok working off the left speaker terminal. Seems to be problem with output from right...
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
Dec 29, 2009 | Cambridge Audio Azur 640A Amplifier
My amp states overload protection and no sound from both front speakers but all other speakers are working
Unplug speakers. Try headphones - are they working? Are speakers correct impedance? If it says 8-OHMs output, are you using 2-OHM or 4-OHM speakers, if so, not good. Sound like wrong impedance speakers or a short in the speaker wiring/connector.
Dec 29, 2009 | Cambridge Audio Azur 540A Amplifier
Left channel not working: makes fuzzy sounds and lacks power
output transistors faulty or possible speaker protection relay contact problem
Dec 28, 2009 | Cambridge Audio Azur 540A Amplifier
Left output ports for both left and right channels do not work
Hi, first thing to do is to check the power supply look for a larger capacitor & using voltmeter measure both sides from ground to positive & ground to negative. Next check the speaker protection circuit if active. If not active measure the voltage from ground to the speaker output before the relay of speaker protection device. The voltage should be zero or close to zero volt. If more then the power transistor or power IC is toasted.
Aug 10, 2009 | Cambridge Audio Azur 540A Amplifier
Can't connect amp to speakers
MOST amps have a small plastic plug in the center of the amps speaker output sockets use a small screw to pull these out.
CABLE GUY.
Feb 22, 2009 | Cambridge Audio Azur 540A Amplifier
I am not very technically literate with respect to audio/video. I purchased a Cambridge Audio Azur 840a V2 Integrated Amplifier last week to replace an Arcam A70. I have a pair of Tannoy DC3 speakers, as...
get an Ohmmeter, take a reading on each speaker line one at a time, on both A & B speaker lines. You should get a reading of 8+/- ohms. The speaker switch with the 6 spks will probably read almost 0 ohms when all 6 are running. That is what your amp is not liking. Try running it with one set of speakers on the switch,with the Tannoys on ch A on your amp and the switch on B. add one pair of the 6 at a time and you'll see that it won't like all 6 at once. 2, maybe 4, at a time is probably what you'll find to work.
Good Luck.
Dec 18, 2008 | Cambridge Audio Azur 840A Amplifier
Speaker Connection
Put teh wire of the cable in the side of the plugs once you have untwisted them - they dont come out.
Feb 16, 2008 | Cambridge Audio Azur 540D
270 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
