Question about Kenmore Kitchen Ranges
I have a kenmore eletric range model 970-502922 the bake and broil elements suddenly dont work everything erlse works and there is no error code what could it be
Amigaman
  • 248 Answers
SOURCE: broil element will not work
You need to check the oven sensor. It should be about 11k ohms. This is the metal rod in the back top of oven cavity. Access it from the rear. UNPLUG POWER FIRST!!
Posted on Nov 04, 2007
fridgetech
  • 473 Answers
SOURCE: 970-686133 Bake and Broil Element not working
Typically what happens on on these models, when the bake element breaks, it sends a surge back to the oven control (or clock) and causes it to fail also. Sounds like this is what has happened here. If the overlay (touchpad) is a separate piece, you will need to buy it also. Let me know if you have any questions.
Posted on Feb 25, 2008
  • 5603 Answers
SOURCE: Kenmore model 790-96614407 oven stopped heating
Check that you have not lost one side of the 240 volt line at the receptacle. This would be MOST noticeable on the oven but would also reduce the cooktop.
Beyond that, the thermostat and oven timer are suspect.
Inadvertently setting a delayed start of the oven could cause it of course, but that would be obvious.
Posted on Oct 27, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: oven won't heat on broil or bake.
Typically - Heating elements will not fail at the same time - nor will relays.... so your CLOCK is the culprit in this situation.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
Kenmore electric range/ovens
Most likely the clock / control or a thermal fuse if your model has one.
Oct 09, 2017 | Kenmore Ovens
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
I have a Kenmore Range Model # 970-5060 and the top element will not work on bake but will on Broil. What is the problem?
No problem - that's the way it is supposed to work.
Note: in some ranges/ovens, the broil (upper) element is a little bit of the time to help even out temperatures, but it will not glow red.
Oct 10, 2014 | Kenmore Kitchen Ranges
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Sears (Kenmore) drop-in unit, Model 911.4698815. Ran the self-cleaning cycle - now it's showing Error Code F3 and neither the bake element nor the broil element will work. Any help would be...
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Sep 12, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Feb 25, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Broil element will not work
Nov 03, 2007 | Kitchen Ranges
Kitchen Ranges Logo
89 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
