Question about Canon PC-1060 Black and White Copier
Black bar at bottom of copies - Canon PC-1060 Black and White Copier
    New Friend:
    Problem Solver:
  • 9 Answers
The bulb may need to be changed..may be dimming
Posted on Dec 10, 2012
How do i forward text message
Hold your finger on the text message you want to forward. A bar will appear above it saying "Copy" and "More...."
Click "More..." and a checkbox will appear next to the message.
At the bottom of the screen you will see a trashcan and an arrow pointing right.
Click the arrow and you'll be able to forward the message.
Alternatively you can always just copy and paste it.
Mar 03, 2015 | Apple Working Black Att Iphone I Phone 3gs...
This Canon MP530 will print a nozzle check with no problems. It will color copy with no problem. No ink cartridge lights are on. It will not print a report or copy in black. What's wrong?
On your nozzle check, do you see the grid at the top (indicated by red arrow in picture below)? If you don't see this, your pigment black nozzles aren't working. The black bar at the bottom is from the dye black nozzles (small black tank). You may have either plugged nozzles or a bad print head.
Mar 02, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Faint black bar rolling from the bottom
if the bar is black or purple you can try to use a ground lift plug and see if your having a grounding issue.
Jan 15, 2010 | InFocus ScreenPlay 4805 Multimedia...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Black Bars on the copy page
It sounds like you have a bad scanner unit.
Oct 27, 2008 | OKIFAX 5400 Plain Paper LED Fax
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Canon PC-1060 Black and White Copier Logo
52 people viewed this question
old marine
old marine
