Question about Polk Audio DSW PRO 600 Subwoofer Speaker
Polk dsw 600 schematic - Polk Audio DSW PRO 600 Subwoofer Speaker
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Posted on Mar 31, 2010
gopakumarg43
  • 74384 Answers
SOURCE: Polk DSW Pro 600 quit
Hello
There is some short inside its circuit board, and you are seeing the short indication. Usually, the short will be with its output section, especially output to subwoofer. In an output short, we cannot predict the which components have failed, because, modern sets' output section is closley related to its tone amp section, directly coupled with. Therefore, there may be some fault occured to that stage also. Sometime it may not be. But when replacing components in its output section, most of the tonel section components also should be checked, otherwise the replaced output component will fail as soon as you switch on the set. If you have sufficiant knoledge in digital elelctronics, you can do it by yoursef. A good qulaity digital multimeter must be with you to proceed. The more you need is patience and concentration. if you have all, go to its woofer output stage, and check for faulty component. OK.
Posted on Mar 15, 2011
Help with repairing this product, Polk suggests replacing the amp !!
To troubleshoot this you need at least an ESR meter. Capacitors can fail with no outside indication.
Jun 19, 2016 | Polk Audio DSW PRO 500 Subwoofer Speaker
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
Polkaudio dsw 660 green light no out put
I have the same issue. It started after the phase switch (0 degree or 180 degrees) broke. Light is green but no sound.
May 12, 2014 | Polk Audio PSW10 Subwoofer
Micropro 2000 has power but has no sound even for test tones. No test tones. What is it?
This could be either a source or a sub problem.
The missing piece to this puzzle is the source identity and setup. Is IT set up correctly for a subwoofer?
If you want to test the sub by itself just temporarily feed one of your FRONT speaker outputs directly to its Speaker IN connectors.
... Or ANY device or source you have can be directly connected to its RCA Line In. BE WARNED - IF IT WORKS IT WILL BE LOUD
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Polk-Audio-DSW-microPRO-2000-Subwoofers-manual/id/23015dj593/t/2/
The unnamed elctronic source will have a manual, too. Use it to troubleshoot.
Jul 08, 2011 | Polk Audio DSW MicroPRO 2000 Subwoofer...
Polk DSW Pro 600 quit working suddenly. The front LED will not come on. In the AUTO mode the light in continuously orange. In the AUTO and ON modes the light blinks green and you can hear a series of 6...
Hello
Mar 15, 2011 | Polk Audio DSW PRO 600 Subwoofer Speaker
I unplugged my rca cables from micropro 4000 and it made a loud boom. Now it no longer puts out any bass. I pushed on the sub and it feels good. The sub powers on just no bass.
Open the case and check the resistance value of the actual speaker - should be around 8 ohms. If it doesn't get a reading, then it's bad.
Jan 01, 2011 | Polk Audio DSW MicroPRO 4000 Subwoofer...
Got a brand new dsw pro 500 and hooked it up to a new pioneer elite receiver through the LFE input. LFE and subwoofer are turned on but the sub does not make sound.... whats up?
if there is multiple jacks on the sub be sure they are hooked up correctly simple mistake if not no doubtly a simple overlooked setting on your amp good luck you will get it
Nov 20, 2010 | Polk Audio DSW PRO 500 Subwoofer Speaker
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
Polk Audio DSW PRO 600 Subwoofer Speaker Logo
180 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
