Question about Samsung HT-X200 Theater System
How has anyone solved this problem cause I got the same
Won't read any disks, makes a whirling noise and crackles through speakers when played through telly, payed a lot of money for this player and always get samsung products but this is rubbish
    Problem Solver:
  • 11 Answers
Did you try air duster or removing the dust from the scanner eye?
Posted on Dec 10, 2012
  • Andrew marsh Dec 10, 2012
    Hi there, thanks for the reply but what is air duster and how do u remove dust from the laser eye
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
My Mackie SRM-450's both make excessive white noise, one of them crackles quite loudly.
This type of active speaker by Mackie has a issue with operational amplifier ic's inside, they are just those little black things with 8-pin soldered to the pcb, you may have some of them damaged, because of the erratic operation of the units, let me know if i can help more.
Jul 04, 2013 | Mackie SRM-450 System
Amp crackling noise
Sounds like you could have a blown amp/speaker or you've got a short in your speaker lead. Typically, when there's not enough resistance on a wire is when you start getting the crackling noises.
Aug 06, 2012 | Televison & Video
PS3 won't accept certain disks. A few disks i have won't play in my ps3. it happens to both blu-ray movies and games, and it seems to only happen with blu ray disks. i'll put the disk in, and...
Hello
The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens.
Try using a lens cleaner to remove dirt and clean lens.
Also i read an article that using a wireless controler can also cause freezing of the blue ray.
Oct 01, 2011 | Sony Playstation 3 (PS3) Console
My speakers will start to make a crackling sort of noise then stop. Sometimes the radio will not play at all. Sometimes the speakes make this crackling noise then they stop making the noise and play ok for...
Are your speakers factory? Sometimes the wires start corroding from moistures or from not being covered well. If you can or know someone who can, you may try checking the wires to the speakers/radio. If they are corroding, they may be shorting out.
Jun 30, 2010 | 2005 Kia Amanti
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Technics amp crackle and ''hiss'' noise
in my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
May 25, 2009 | Audio Players & Recorders
Speakers are making a crackling sound then cut out.
Sounds like an internal loose connection somewhere, possibly anywhere, a connector on a pcb, a dry solder, loose pin on an IC. Tough for an end user to solve this, would entail opening the unit and investigating. I checked the rear panel in the op manual and this model has no ribbon connectors else i'd have asked you to check them.
Mar 26, 2008 | Aiwa NSX-DS55 CD Shelf System
JVC RX558 VBK, Crackling noise from speakers
A quick quess of mine is the following:
The OVERLOAD indicator lights up when the receiver is maxing out on the current it is sending to the speakers. My guess is there is possibly something wrong with the receiver itself, especially since the B speakers won't play. Either that, or something is broken in your speakers or you are using a set of speakers that have too low an impedance rating for your receiver.
Apr 23, 2007 | JVC RX-558V
Samsung HT-X200 Theater System Logo
119 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
