Question about Canon Office Equipment & Supplies
How to read ink levels in canon mf 8080
Toner levels
SOURCE: Canon MP560 ink level override
I have the same problem, BUT once the printer detects the cartridge is either empty OR replaced by a generic, it does NOT print at all. It freezes up and refuses to do anything (scan to USB, scan to PC, scan to PC application) until you put in a genuine Canon cartridge. My previous iP PIXMA 4000 the MP560 replaced worked fine with generic cartridge refills. Had for 5 years. But the MP560 is smarter. How can you override this problem? Thanks TDK
Posted on Mar 04, 2010
canontech
  • 1219 Answers
SOURCE: canon imageclass mf 6530 blank pages change toners
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
Posted on Jul 19, 2010
tbreeze47
  • 3083 Answers
SOURCE: Canon image class MF 4150
Here's a short blog of the problem, and talks about the toner sensor:
http://www.pcreview.co.uk/forums/thread-3635665.php
This page shows the insertion process, although it sounds like you're not having a problem with that:
http://www.retrevo.com/c/sohohelp/blogs/show/15190/Getting-error-message-toner-is-not-set-Insert-Toner-for-my-Canon-MF-4150-printer
Actually, go to this Amazon.com page and read the first two reviews- there is a link to a "fix" that helped another user:
http://www.amazon.com/review/RZPU9JFTRI2US
Hopefully, this will get you going. Good luck, and thanks for using FixYa.
Posted on Sep 04, 2010
Possible contacts cartridge or laser unit is closed.
Posted on Mar 15, 2011
  • 49 Answers
SOURCE: my canon imageclass mf 4150 says toner not set but
you have to make sure the cover is completely closed:
http://www.quikshiptoner.com/catalog/mf4150-toner.html#_How_to_Change_the_Toner_Cartridge_in_a_Canon_imageCLASS_MF4150_Laser_Printer
Posted on May 25, 2012
Canon mf 8340 will not scan despite full reinstall. Black toner level is low
When it won't scan will it copy, please? Will it print?
Best wishes,
Robbie
Mar 17, 2015 | Canon i-SENSYS MF8340CDN Laser...
Canon printer MF 8080 cw will not reset after a paper jam
Hello, If the printer will not reset then you still have a piece of paper stuck somewhere in the paper path. Did you power the printer down and back up? Here is manual.
Canon imageCLASS MF4150 Manual
Sep 30, 2014 | Canon imageCLASS MF4150 All-In-One Laser...
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
How to Check the ink level in cannon lbp 2900
The Canon Laser Shot LBP2900, does not use ink(liquid), it uses a Cartridge called "Toner" which contain "black powder" form in the cartridge capsule.
If you wish to check the Toner Level, refer to this guide @ http://support-in.canon-asia.com/contents/IN/EN/8100134600.html
Hope it helps.
Jun 15, 2011 | Canon LASER SHOT LBP-2900 Printer
Canon mf 6540 copies come out uneven
Did you clean beneath copy glass ( adf copy glass and platen )?Did you clean scaner also?
Clean the laser unit.
Not genuine toner isnt best solution.
Try to print something.If the print is OK, then the problem is in copy glass and scaner.
Jul 02, 2010 | Canon ImageClass MF6540 Copier
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Printer not printing
Clean the heads, the printer is not reading cartidges. Is yours a model that needs the ink levels reset to funtion correctly, then do this too.
Feb 13, 2008 | Office Equipment & Supplies
87 people viewed this question
old marine
old marine
