Question about Dell Inspiron 530 Desktop Intel Core 2 Duo 2.2ghz 2gb Dvdrw 500gb Dvdrw White
No screen 2 bips fans run 1GB RAM - Dell Inspiron 530 Desktop Intel Core 2 Duo 2.2ghz 2gb Dvdrw 500gb Dvdrw White
  • Dell Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Remove added memory If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer. Swap memory location If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory. Try another computers memory If you have access to another computer that uses the same memory, try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced. Replace memory If it is determined the memory in the computer is bad we suggest that you replace it if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible b> Hope this helps.
Posted on Dec 11, 2012
  • Mathieu-Charles Dec 11, 2012
    Thank you very much it works perfect
  • Brian Sullivan
    Brian Sullivan Dec 11, 2012
    Thanks for replying with the good news and hope it all goes well for for you
HP DV6000
It is commenly known thay the bips may refer to a Ram crash or misplaced maybe because you have laptop has been shaked unproperly. Try to check up your RAM slots ;)
Jan 23, 2013 | Computers & Internet
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
Cpu fan running high speed for acer power fv 519 1gb ram, vista operating system,
i have acer power fv desktop win 7 1gb ram ,CPU fan running high speed
Jan 22, 2012 | AcerPower FV PC Desktop
I have 1Gb memory in A1 & A2 Power is
check your ram modules and also check if your video cards fans are running right. If both are ok then try clearing the bios it should work out
Nov 17, 2009 | ASUS NCT-D (90MSV430G0UAY) Motherboard
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
ASUS MOTHERBOARD P5B-MX WIFI WON'T DISPLAY
Are you sure the onboard video is working? Try an external card and see if this works. All the beeps when you remove the memory is good because you know the processor is working.Are you sure you have the right memory? Some machines won't boot or anything when you have the wrong memory.
Dec 13, 2008 | Computers & Internet
Hi sir i have an acer aspire 5101 which bips when i swtich it on and nothing shows on the screen.i have checked the ram an hard dive and they both ok
1st step you can check how many bips you hear, if continous bips , checks your vga by change with other if you sure that your ram and hd is ok, 2st if problem isn't solved ,remove all your card and clean all contact part all card with liquid cleaner, pci slot vga slot ram slot and processor socket after that you can try to assemble your card again , ok good try
Sep 26, 2008 | Acer Computers & Internet
What does the bip sounds sounds mean on my pc
Its probably bad ram chip. Check that it is seated correctly. Then use another PC to do a google search on beep codes and isolate the actual problem by you PC bios type..
May 08, 2008 | Tiny Computers B1996 19" CRT Monitor
Dell Inspiron 530 Desktop Intel Core 2 Duo 2.2ghz 2gb Dvdrw 500gb Dvdrw White Logo
213 people viewed this question
Alun Cox
