Question about Dell Inspiron 1501 Laptop
Ddr2 533 to ddr2 667 memory
I just want to know if its ok that my dell laptop can go upgrade to 2x1gb ddr2 667 from dr2 533?can anyone know if its ossible and no effects to my laptop?thanks!
  • 1 more comment
  • enigma pulp Jan 13, 2009
    Dell inspiron 1501,vista home basic,512mb ddr2 533....setc..
    may laptop is supported a upto 2gb memory but my problem is can my laptop can upgrade from 533 to 667 because i lost my manual of my laptop..
    my laptop support upto 2gb memory but i just want to know if i can go to ddr2667 even it was only 533 because i lost my mnaul pls..help me bout this..tnx
  • Dell Master
  • 32,281 Answers
There should be no problem because the new RAM speed is faster than your old RAM, but your system cannot make use of the extra speed unless you can change it in the BIOS setting. Your BIOS should be able to support 2.0Gb, but check your specification, go to the DELL WEB site if you don't have the specs.
Posted on Jan 13, 2009
  • Chris Hingee
    Chris Hingee Jan 13, 2009
    Go to the www.dell.com to get a copy of the manual for you model laptop. The best way to get the correct manual is to use the Service Tag number, it is printed on a label on the bottom of your laptop.
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Would like to upgrade my memory for my 5520-5334
Supported memory for the laptop is >>>>>
  • Memory Speed (MHz):667
  • Memory Type:DDR2 SODIMM
  • Memory Size (MB):2048 Mb
  • Max Memory Size:2Gb (2X1GB)
Go with Kingston or Corsair as the manufacturer.
Regards.
Aug 18, 2009 | Acer Aspire 5720-6661 Notebook PC
I want to upgrade my memory. my current memory is 2x256mb pc2 3200. what is the max limit of memory can i have? is it per slot or total? if i get pc2-5300 is it backward compatible to pc2-3200? anyone with...
You can have a maximum of 2GB in that laptop 1x1GB in each slot, the ram speed is PC3200, PC5300 is too fast so the bios will not recognize it as the maximum is only 400MHz, stick to the PC3200 for each stick.
Ask for SODIMM DD2 SDRAM, PC3200 2x1GB, i also recommend Kingston as the ram manufacturer.
Regards.
Aug 01, 2009 | Dell Inspiron 6000 Notebook
Upgrading my Dell Inspiron 8200 laptop
I have a Dell Inspiron 8200 P4 2.4ghz and I install 2gig or ram and it works great ddr pc2700 333mhz for $69/gig at bestbuy. I really notice the difference. I also install a 160 gig HDD.
Mar 17, 2009 | Dell Inspiron 8200 Notebook
I need to know how much memory I can add to my PC?
Your machine's max memory is 2GB. It takes several flavors of ram so here is a link that lists the types of memory you can use in your machine.
Note: I don't necessarily endorse or recommend the seller's link I've included, it's simply for illustrative purposes.
Feb 24, 2009 | Dell Dimension 2400 PC Desktop
Memory Upgrade Problem
Some of the motherboard DIMMS got limitation. U need to check back the manual. Cannot simply insert different type of speed and capacity on each DIMMs.
Feb 13, 2009 | Acer Aspire™ T180 PC Desktop
Verify memory upgrade in a Inspiron 1200
Verify on the label of the the memory Dimm that you installed that it is PC2700 SDRAM.
Memory Upgrade for Dell Inspiron 1200 Laptop, the Dell Inspiron 1200 Laptop takes the PC2700 DDR SDRAM SODIMMs. Memory Type, and comes installed with 256 MB (non-removable) of Memory. You can upgrade your Dell Inspiron 1200 Laptop to up to a maximum of 1280 MB Memory, the system has 1 socket to install Memory, already with 256 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Standard Memory 256 MB (non-removable) Maximum Memory 1280 MB Memory Expansion 1 socket Memory Comments PC2700 DDR SDRAM SODIMMs. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | Dell Inspiron 1200 Notebook
Upgrading
you can upgrade the memory. just replace the 2X512 MB sticks with 2X1GB sticks
Jun 10, 2008 | Gateway MX6424 Notebook
Dell Dimension E510 memory upgrade
Please check the type of RAM you are using.
You must return it to BestBuy and try using a Dell store.
Call Dell Accessories sale and they will be able to give to better options and it wud work too.
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Inspiron 1501 Laptop Logo
91 people viewed this question
Alun Cox
