Question about HP LaserJet 4250n Printer
ERROR 41.3 UNEXPECTED SIZE IN TRAY 2 - HP LaserJet 4250n Printer
CompuGuy44
  • 432 Answers
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
Check your settings under the properties menu. and in the software your using.
Posted on Jun 26, 2007
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
Posted on Jun 11, 2009
  • 26 Answers
SOURCE: Iam facing in hp 4050 printer,when i have giving
swap trays and test - if OK then your tray is set up wrong. remove paper and check that it is set for letter. also check the small switch (if there is one) on the Right hand side of the tray that maybe set to customer - change to standard. compare trays so they look the same - and check the settings in the menu for letter / plain on both trays
Posted on Jul 24, 2009
  • 150 Answers
SOURCE: hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Posted on Mar 11, 2010
Prefab
  • 152 Answers
SOURCE: printer says 41.3 unexpected size in tray 2. How
A couple of things to check.
1) Make sure the paper guides in the tray are adjusted correctly for width and in particular the length. 2) Remove the tray completely check guides. 3) Make sure the tray is fully seated into the printer. 4) Make sure the paper in the tray matches the size of the guides.
If the guides and paper seem OK, the printer may need servicing by authorized service center.
41.3 UNEXPECTED SIZE IN TRAY [xx] alternates with LOAD TRAY [xx]: [type] [size] Description This is typically caused if two or more sheets stick together in the printer or if the tray is not properly adjusted.
Posted on Jan 14, 2011
Error 41.3 on a 4345mfp
41.3 UNEXPECTED SIZE IN TRA 2
Dec 08, 2011 | HP LaserJet 4345mfp Printer
Unexpected paper size in tray 2.the paper in tray 2 is legal size..8.5 x 13 custom size in philippines..
Papers come in different standards across the world. This size is neither US nor metric. You will need to set the printer for custom-size paper and enter the dimensions.
Oct 13, 2011 | HP LJ 4100 Series Black toner 6K Printer
41.3 unexpected size in tray 2.my printer is hp laserjet 4200.can you solve this
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet 2420 Printer
Printer says 41.3 unexpected size in tray 2. How do I fix this?
Jan 14, 2011 | HP LaserJet 2420 Printer
My printer keep saying "
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
Nov 09, 2010 | Office Equipment & Supplies
Hp 4000N 41.3 unexpected paper size
Mar 11, 2010 | HP Office Equipment & Supplies
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
Mar 22, 2007 | HP Color LaserJet 3500 Printer
HP LaserJet 4250n Printer Logo
393 people viewed this question
Seeker5211
Seeker5211
