Question about Zanussi 29 in. LS14 Free-standing Dishwasher
Zanussi ls9 dishwasher
I am getting a C 2 message on the display of my zanussi LS9 dishwasher then the machine stops working. What does this mean?
Check your boiler,maybe there is no water there
Posted on Aug 03, 2008
SOURCE:
Error code c 2 ls9 dishwasher
Good Afternoon Paolo, thanks for your post!
I see that you need to reset your Electrolux dishwasher due to replacing relay and an error code. The best way to reset your dishwasher is to disconnect power from it for roughly ten minutes. I hope that this information is helpful to you. -Matt
Feb 27, 2015 | Electrolux Dishwashers
Zanussi dishwasher LS9 AD/G1 reading code C8 and not working
C8 - During rinse phase boiler doesn't empty:
  • Rinse pump not efficient.
  • Rinse arms obstructed.
  • Boiler level sensor out of order.
Dado
Jun 25, 2012 | Zanussi 29 in. LS14 Free-standing...
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi LS 14
for remove C8 error on zanussi LS14 you must press on/off and press cycle2 key and you get FAC press cycle2 key again 8 times and you get CFG enter on family of this paremeter pressing ifinity key go to parameter ALR and you get ALR= 1 change to ALR=0 AND FIX THE PROBLEM.
Feb 28, 2009 | Zanussi 29 in. LS14 Free-standing...
Zanussi ls9
write to me if you need the manual.as for the soap the dishwasher uses only liquid professional soap and you must connect it inside the tank . there is also a blue pipe for the rinse aid detergent
let me know if you need anything else
Mar 21, 2008 | Zanussi 29 in. LS14 Free-standing...
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi 29 in. LS14 Free-standing Dishwasher Logo
1,439 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
