Question about iSkin Cerulean RX A2DP Wireless Bluetooth Streaming Audio Receiver with iPod Connector and Line-in
Iskin cerulean rx not working with my home theater
I recently got the iSkin Cerulean RX for streaming music from my IPod to my Yamaha home theater that includes a docking station for IPod. The problem is that although pairing the Cerulean with Ipod is very easy, once they are already paired, the Creulean does not play the music I select form the Ipod. I realized that this malfunction only happens with 2 of my devices (the home theater and a digital clock). However, if I use the Creulean with older devices, it works perfectly well. Can anybody explain me why it works in sime cases an why it doesn't with other devices? Thanks and regards Arturo
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha
usa.yamaha.com > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
www.fixya.com/.../t25422640-no_sound_yamaha_rx_530_stereo_fm
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
Jan 12, 2016 | Yamaha RX-V540 Receiver
My yamaha rx-v795a works fine but the display is showing jibberish. What is causing this problem?
There is a Microprocessor(computer) that controls the display. This Micro can be bad, the display can be bad, the connections between the two, as well. For more information, please visit my website at audioserviceclinic.com. Thank you.
Sep 18, 2013 | Yamaha Rx V795a 5.1 Chan 425 Watt Home...
Yamaha av Receiver RX-V465 picture but no sound. Can switch between PS3 and sat tv all via hdmi connections. Good picture yet still no sound. Trying to run left right and center Bose speakers. Read the...
Check the settings on receiver in the SETUP menu / HDMI / Audio. Here you can choose Amp (sound goes from the speakers connected to receiver), TV (receiver is muted and sound is routed via HDMI to TV) and Amp+TV (sound goes from speakers and also to TV).
Also check in OPTION menu / Signal Info that receiver is receiving sound in recognized format.
Jul 04, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Ipod video onto TV through RX v365
No it is not. TV out requires special cables that can be purchased for the iPod.
Jan 12, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have yamaha rx-v465 receiver and yds-11 docking station. how can i get tv{through hdmi 1}to display what's on ipod.i have nano w/video camera{newest one]. is this possible
I think it is not possible, because RX-V465 does not have HDMI-video processing. It can only pass-thru the HDMI video to HDMI-out, but not alter the signal in any way.
If it should support TV output with YDS-11, it will work only via analog video out (s-video / composite / component).
Dec 30, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
I have HDMI cable from TV to RX-V365. HDMI from DVD player to RX-V365. HDMI from DirectTV receiver to RX-V365. Speakers attached. I can watch the TV and the DVD player... but the sound is still coming...
the RX-V365 cannot process the audio from the HDMI input. You will also need to connect a seperate audio input (either coaxial or optical) into the relevant input in the rear of the RX-V365
Dec 12, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
My ipod issue
Apple sent the iPod nano back to me in factory reset condition (this is expected). And, in fact, the nano worked fine for a while after being returned to me in that state. Is it the case that nanos need to be factory reset every few months? I factory reset my unit using the March 23 update this evening after the problem started up again. And, the unit seems fine again after doing that and reloading my song/podcast library. Is the tight iSkin case with hard plastic covering for the thumb wheel somehow causing the wheel to press the Select-Play combination that causes a normal reset? I should call/email iSkin and ask about this. But, how about anyone else out there with other similar case designs that includes a hard plastic cover over the circular control? Of course, it could be that I just have a one-of-a-kind slightly flaky unit that passes Apple?s diagnostics because of some oddball unique problem. If you have a similar issue, chime in (especially if you can explain it :-).
Apr 28, 2007 | Sony PlayStation Portable (PSP) Console
iSkin Cerulean RX A2DP Wireless Bluetooth Streaming Audio Receiver with iPod Connector and Line-in Logo
Top iSkin Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an iSkin Audio Player and Recorder Expert? Answer questions, earn points and help others
