Question about Xerox Office Equipment & Supplies
Fault code 077-312 is on the screen and wont start up the printer, what can i do Regards
    Master:
  • Xerox Master
  • 442 Answers
2 Suggested Answers
SOURCE: fault code 077-312 is on the screen and wont start
Posted on Dec 10, 2012
What is Xerox Phaser 8560mfp fault code 00,006.74?
Hi Anonymous,
You need to contact your the www.xerox.com website.
Regards.
Jul 28, 2014 | Xerox Phaser 8560MFP Laser Printer
Why won't my printer start up ?
Count the pattern of orange to green flashes. This gives a code that will allow you to identify the fault. Then look up canon error code on google or similar and you should find out what your machine is fussing about.
Jul 28, 2014 | Canon PIXMA Office Equipment & Supplies
Fault code p1000
You can take it to car service they can clear the codes. Or you can DIY by disconnecting both leads to the battery and touching them together, computer should reset to factory default, and reset only valid fault codes as you drive and it learns.
Apr 06, 2014 | 2004 Jaguar X-Type
Starts but runs ruff then dies
Hi Glean, Sounds as if you have a problem with the fuel pump or possibly the air flow sensor. Take the vehicle for a scan and if no fault codes show up suspect the pump. Regards John
May 18, 2012 | 1995 Nissan Maxima
Hi i have a 2004 bmw 320d just fitted a recon engine and wont start coming up with crank shaft sensor fault put a new one on and still wont start any suggestions please thanks
Hi Mountview,
First thing I'd suggest you do is delete the fault codes from your scanner....The engine management computer stores them, and they may be from your old engine?
Run another scan and if the codes come up again check the cables to the sensor. Defective parts are not unknown, especially where I am....
The anti theft device may have kicked in and be inhibiting starting....This will require resetting on your scanner.
Once you've checked all of that, bleed the diesel system, as if there's any air in the fuel line, it won't start
Regards Johngee10
Nov 19, 2010 | BMW 3 Series Cars & Trucks
Nov 12, 2010 | Xerox DocuColor 12 Color Copier
Fault codes 14 & 15 ATC sensor failures. Developer beads had been replaced and printer was working. Then codes appeared. Tried to clear fault codes by holding back and info buttons while turning on...
Hi.
On Xerox Faser:
Remove the Rear Cover , and Rear Shield , Measure the voltage at P534-5 on the Engine Control Board. Does the voltage measure between +1 VDC and +3 VDC?
Yes - Replace the Engine Control Board
No- Replace the Developer Housing Assembly
Replace the Engine Control Board , Replace the Developer Housing Assembly.
Regards.
Nov 19, 2009 | Computers & Internet
Car wont start every time i try to start the car it keeps kutting out
If the problem happens only when engine is cold, check air intake, AIF , MAF and vacuum.
If it happens under all conditions, check fuel pump, distribution, O2 sensor.
Doing a scan with an OBDII code reader will probably return fault codes that may help.
Regards.
Jul 31, 2009 | 1997 Audi A4
94 honda d4 flashes and wont start
Hi
Its flashing a transmission related fault code. Count the flashes before and after the pause and it will give you the fault code.
Post it on here as a comment and we'll tell you what it means.
If it flashes a 1 and then an 8 then you need to renew the main relay.
Regards
Geordie
Jun 21, 2008 | 1994 Honda Accord
Freezes and displays white screen when starting
hardware fault ..90% chance at pcb level or short circut at the lcd flex cable? needs troubleshooting.
try a firmware update just to check if this is happening due to corrupted software. I dont thing so but there is a small chance..
Regards Theo
Feb 11, 2008 | Sony Ericsson W300 Cellular Phone
512 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
