Question about GE Kitchen Ranges
Ge electric oven trouble shooting
When you turn on oven the broiler comes on
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 10, 2012
  • 100 Answers
SOURCE: Oven wont start
The control sends voltage down to the ignitor, the ignitor glows red, when and if the ignitor gets hot enough it opens the gas valsve to let gas in which is then lit by the ignitor.
If ignitor glows either the ignitor is bad or the oven valve
If the ignitor does not glow then either the ignitor is broken, the control is not sending voltage down, or the oven valve is bad and not sending voltage to the ignitor.
In most cases it is the ignitor which is the cheapest of the three parts
Posted on Oct 30, 2007
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Posted on Jan 08, 2009
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
  • 29 Answers
SOURCE: Oven will not turn on.
GAS OR ELECTRIC?
Posted on Jan 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
My GE oven Model # T BP67BOD1WH electric coils do not heat up. What to do?
I have a GE Spectra jbp67b0d1wh Electric Kitchen Range when all nobs turned off the broiler comes on smoken hot what can this be
Oct 02, 2010 | GE Spectra JBP78 Electric Kitchen Range
How do I troubleshoot my Magic Chef electric built
Hi,look in the control console for the tech sheet or under the top of the unit.A good place to start.Hope this helped.
Nov 17, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Ge extra large self cleaning oven xl44 mode jgbp28ded1wh
Check to see if the ignitor glows in the oven. If it does not come on or comes on very dim, you have a bad ignitor. It is usually a bad ignitor. They are very simple to replace. Just unplug the oven first. Then take off the bottom of the oven floor inside the oven to access the ignitor. the ignitor has 2 wires going to a plug, just unplug the plug and remove the mounting screws. Take your ignitor to a local appliance store to get a replacement. There are 2 models of ignitors so bring the old one with you to make sure you get the right one. Good luck..
Oct 07, 2008 | GE JGRP20 Gas Single Oven
Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
Apr 15, 2008 | Frigidaire PLEB30T8A Electric Double Oven
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
