Question about Xerox Phaser 7400/DX Laser Printer
Phaser 7400 squeaks while printing - Xerox Phaser 7400/DX Laser Printer
  • 20 Answers
Id try lubing the feed rollers well the metal bars where they contact the chassis and lube gears and stepper motors. its been awhile since ive had my phazer. i traded it last year to my church pastor but try that. radio shack sells a teflon lubricator part no. 64-2301a and im certain amazon also sells them. ONE drop goes a LONG way. its also a miracle worker for pc fans, and household appliances as well as automotive where its not high heat. even bearings.
hope this helps you a tad sorry i cant be more of a help here but thought id pass a few personal experience in fixing electronics/mechanical tips along.
Posted on Dec 11, 2012
  • Geoffrey Walker
    Geoffrey Walker Dec 11, 2012
    oh as an addition its quite possible it could be within the opc drum or the toner cartridge. same thing there lube any gears or mechanical assemblies but with the drum, feed belts(if applicable) and toners or fusers DO NOT get lube on the print surface. it will prob screw things up worse.
  • 2072 Answers
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Posted on Mar 07, 2008
faxman789
  • 297 Answers
SOURCE: my printer phaser 7400 can not start no signal no thing
Make sure the printer is plugged directly into a wall outlet, not a surge protector or multi-outlet strip. These devices will limit the amount of power to the machine, causing it to not initialize properly.
Posted on Jan 17, 2009
  • 110 Answers
SOURCE: Phaser 7400 LCD is blank. How can that be fixed?
Once the LCD is gone blank that means you have to change the control panel. it's not difficult to change, all you have to do is remove the covers that are behind the the control panel. Once you have removed the white covers you can now unscrew the metal hinges. Then you have to insert a flat head in the small cracks behind the control panel that opens the control pane blue covers. Now you disconnect the data cable that connects from the control panel to the machine and that's it. Hope this helps
Posted on Nov 02, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 4510 - While printing it makes a squeaking noise
One of two things. The fuser bearings get noisy in those.
Or there are several small hard plastic rollers on steel shafts or even mounted on springs they they can get very noisy.
Posted on Feb 24, 2010
  • 17 Answers
SOURCE: xerox phaser 7400 I'm getting large black streaks
That would be the drum 99% of the time. A fuser is what heats up the paper and the toner so it will stick properly. If it is "smudging" then its the fuser. But is it is lines sometimes with dots in them that is a bad drum.
Posted on Apr 03, 2010
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Xerox 7400 wont print colour
Did you load up the "Universal Printing Driver"??? it only prints monochrome on most Xerox printers...
You should use the PostScript Driver for this printer.
Dec 02, 2011 | Xerox Phaser 7400/DXF Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Phaser 7400 not printing red
I would suspect you do not have drive to the red imaging unit area. A gear may have fractured, a motor not runing, which would normally give you a fault code, or a clutch is slipping not driving the red components.
Jul 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
My printer phaser 7400 can not start no signal no thing
Apr 02, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DX Laser Printer Logo
157 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
