Question about Refrigerators
Maytag mbf1958xe runs constantly, freezer is same temperature as fridge.
Both freezer and fridge portion are @ 40 degrees F. Unit runs nonstop.New unit,no dirty coils etc.Unplugged for 2 days,so frost not an issue.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
You need to test the thermistor in the unit. It should read around 10,000 ohms at room temperature and around 29,500 ohms at 36 degrees. Here is a diagram for the location of the thermistor. It is 22 on the diagram.
Here is the part to order if you find it bad.
Posted on Dec 10, 2012
  • 2 more comments
  • John Tripp
    John Tripp Dec 10, 2012
    Greg and Richard once you OHM out the thermister let me know the results. I listed the below should the compressor be short cycling...Thanks JT
  • greg c Dec 10, 2012
    The compressor runs forever,3 weeks straight at one point.Not getting hot or short cycling.Tech said was probably a leak in sealed system.
  • John Tripp
    John Tripp Dec 11, 2012
    Thanks for your response Gregg I suspected that was the problem I was just hoping the compressor start components were defective. John Tripp
  • greg c Dec 13, 2012
    They put a new drier in and some dye.But still could not find leak.I used my electronic detector and found no leak either.What could it be?
  • 4,654 Answers
I need to know if the compressor is too hot to keep your hand on the top. You may have a start relay and run capacitor problem but you will need to plug power back in for awhile. Need to see that both condenser and evaporator fans are running. Do you also have a way to test the compressor? Here is a=> W10136414 Relay and Overload Kit
Maytag mbf1958xe runs constantly, freezer is same  - 12_10_2012_6_54_30_pm.jpg
You will need a good ohm meter to provide this test=> Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
HVAC Ohming Compressor Windings
HVACRH20
  • 237 Answers
SOURCE: Fridge fine, freezer not freezing
Weird scenario... the first thing I would do it to remove the interior back panel of the lower freezer section after the unit has been running for hours and check the coils to see the frost pattern on them. Should be even white frost all over the coils with no solid frozen coil (block-O-ice thing). Check the fan is running above the coils, etc. when. If everything is OK then you may have a control board problem. Let us know what you find in the freezer coil investigation and we can go from there.
Posted on Jan 15, 2007
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
  • 9 Answers
SOURCE: freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Posted on Jul 09, 2009
  • 3 Answers
SOURCE: my westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Posted on Jan 26, 2010
Recommended temp settings for freezer and fridge
The ideal freezer temperature is 0 to 5 degrees and the fridge section from 36 to 40 degrees. However, you will get more accurate responses if you leave the model number of your exact unit.
Jul 15, 2013 | Computers & Internet
Frost build up
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Determine the temperature setting. The refrigerator should be set to temperatures ranging from 34 degrees to 40 degrees, while the freezer should be below 30 degrees. Adjust the temperature setting which will naturally improve the ice buildup that's been caused by the wrong temperature setting.
Move the refrigerator away from the wall. Oftentimes, this simple action is all that is needed because the unit is not getting enough air circulation behind it. Also, some refrigerators have vents underneath the unit, which are easily clogged with debris. Clean these vents and coils.
Remove food and shelving from the refrigerator and freezer portions of the fridge. If ice build up is happening in the freezer, the drain in the freezer may be clogged. With the unit off, remove coverings to expose drain and pour hot water down the drain hole until it comes out into the drain drip pan under the fridge.
Check the condenser coils. The evaporator coils could be causing the problem of ice build up. If this is the case, professional repair is likely needed to replace the motor, thermostat or other problems within the fridge.
Check this link for a detailed idea:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query or else please accept the solution.
Sep 07, 2011 | Refrigerators
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
Both sides are warmer than should be. motor running nonstop
You refrigerator needs regassing that is why things are not cooling. Your sides of fridge are hot because the motor keeps running to keep what gas is there flowing though the lines trying to cool fridge
May 25, 2010 | Maytag MZD2766GES Side by Side...
Freezer not freezing, moves from 8 degrees to 34 degrees. Fridge keeps constant 40. Someone said it was frost temp sensor? Cant even get into interior back pannel to replace now I have the part.
There are 2 thermistors for frost and 2 for temperature....Fridge and freezer compartment have one each.
Access to the thermistor sensors are from the inside of the fridge and freezer. You have to remove the shelves, trays and the inside panels to get at them.
The manual will show you how.
There are diagnostics you can run that will tell you which one is in trouble.
There are sensitive voltages that may be required to measure. So from a tech point of view you may need someone with electronics expertise to do the measurements.
The procedures and various measurements are too lengthy to tell you but I will give you the link to the service manual PDF and you or someone can do the diagnostics...The Manual is 87 pages long. Can you imagine a fridge needing that much documentation.
That said. I have the same fridge and have fought 3 different problems...not fun....
here's the link...
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Make sure you unplug the fridge before you go taking things apart...
Good luck
Maytag owns Samsung
Dec 29, 2009 | Samsung RB215LASH
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag side by side refrigerator
fridge has timer to adjust for defrosting, but the not working working you to manual defrost the unit to avoid ice formation inside the fridge.
Dec 30, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
