I have a philips universal remote that came with my lutron dimmer switch. I lost the instructions but i want to hook it up to my cable box.
My cable box brand is Scientific Atlanta. The remote came with the Lutron IR-600 dimmer switch that I got from Home Depot.
    Top Expert:
  • Televison & ... Master
  • 34,814 Answers
Try 0451, 0351, 0252, 0155, 0852, 0248, or 0251
Posted on Dec 10, 2012
3 Suggested Answers
  • 1335 Answers
SOURCE: trying to program a universal remote to scientific
If you have a URC-7800 the codes 0477, 0008, 0017 should work for the scientific atlanta cable box.
Posted on Feb 05, 2010
gopakumarg43
  • 74251 Answers
SOURCE: need ir code for atlanta scientific cable box explorer 1850
Check this site.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page.
Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
Posted on Jun 03, 2012
Can I reuse a Lutron Maestro MAW-603 dimmer in a 2 way situation?
you should be able to by hooking up the black wire on the dimmer to the hot wire(that comes from the electrical panel) in the wall box and the red wire from dimmer to the switch leg(the wire that goes to light fixture). if the dimmer has a white wire(nuetral wire) you will need to hook that up to the white wires in the wall box....CAUTION!!! when removing the old 1 pole switch, there should only be 2 wires and possibly a green or bare copper ground wire attached to it. if either of the 2 wires(not the ground) are white, IT IS MISLABLED OR MISCOLORED. DO NOT hook the dimmers white wire to it cuz it will fry the dimmer. If this is the case, then most likley you do not have a nuetral in the wall box but look anyway for a couple of white wires tied together with a wire nut and stuffed in the back of the box. if you find those than most likely thats your neutral(check with a wiggy or meter to be sure) and thats where the dimmers white wire goes. hook up the dimmers green wire to a green or bare copper wire in the wall box and then put a wire nut on the dimmers red w/white stripe wire.
Feb 16, 2014 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
Lutron 1000w skylark s-103p. The lights hooked up to this dimmer had always worked. now sometimes when i hit the on buttom they don't come on at all. the dimmer is probably5 years old.What do you...
Older dimmer switches use rheostats to adjust the resistant loads on the switch. Since this is a mechanical operation, over time they become loose or corroded. So it sounds like this has happened to your dimmer switch and you should replace it with a more modern switch that isn't as mechanical.
Jun 26, 2011 | Lutron SKYLARK S-103P Light Control by...
I replaced a standard single pole light switch with a lutron Meastro dimmer switch with remote. It does not work. I replaced the standard switch and all was good. This circuit is on the same line a gfci...
Hello. There could be a couple of possibilities. First is the simplest to verify, is it a Companion Dimmer, Standard Dimmer switches or a 600W or 1000W Maestro Wireless Multi-location Dimmer. The Maestro Companion Dimmers can not be used individually, as they do not control a load, and must be used along with a Maestro or Maestro Wireless Multi-location Dimmer. The Campanion Dimmers are also a line/low voltage rating, and rated for incandescent and halogen but may not handle some flourescent fixtures. The other thing I can think of is that you may have interfearence from another item. They are radio frequency (RF) devices that communicate together for wireless control of lights. Here's two links that may be of some help, the second has downloadable install instructions.
http://www.smarthome.com/6601LA/Lutron-MA-R-LA-Maestro-Companion-Dimmer-Switch-Light-Almond/p.aspx
http://www.prolighting.com/lumamaprsmre.html
Hope this helps out, don't forget to rate this answer.
Thank You,
Richard
Mar 14, 2011 | Lutron SCR-20-GFCI - Dimmer Controls -...
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
Mar 03, 2011 | Philips Lightolier Onset 600W Incandescent...
I have a Lutron Skylark SLV-600p and I want to connect it to control the ceiling fan with light fixture. The chain broke on the ceiling fan and its an old model which the device is inside the light box...
1) It appears this dimmer is not for fan motor.
Dimmer manual says:
"... do not use to control receptacles, fluorescent lighting fixtures, or motor-driven appliances."
http://www.lutron.com/TechnicalDocumentLibrary/030448c.pdf
2) Call Lutron tech support directly:
1-800-523-9466
3) You can replace the pull chain switch to the fan with a bit of dis-assembly and then purchase of new 3-way fan switch at home center. If you decide to do that, add a comment and we can talk details.
4) In order to get a fan-light control to operate from your switch location, you need the following things:
-Fan has to set on high, so unscrew brass part where chain attaches to fan and see if you can grab end of pull chain, and set fan to high.
-Switch box has to be set up to control the light and fan separately. It sounds like your switch box has that capability with a black wire going to light and red wire to fan.
-You need a Lutron combo control that is specifically for controlling ceiling fan, and light fixture.
Call Lutron for best choice.
Last option: 5) Replace fan with new one from home center.
Add a comment if you order the Lutron combo control and I will help you test the wiring and get it hooked up.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on fan or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 25, 2011 | Garden
How to program control with light switch
If I understand correctly, you have the Lutron Pico wireless control
And you have the Lutron Maestro companion switch or companion dimmer
Pico will not work with ordinary wall switch or dimmer >> it has to be a companion product from Lutron
I have read the PICO wireless manual, and it shows no instructions for communicating with the companion wireless switch or companion wireless dimmer
http://www.lutron.com/Products/SingleRoomControls/MaestroWireless/Pages/Overview.aspx
http://www.lutron.com/TechnicalDocumentLibrary/369-144f_Pico_Wireless_Control_SpecSub%20%286%29.pdf
I have read the 120V Companion switch manual and it shows no instructions for communicating with the PICO wireless control
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Single+Room+Controls&prodn=Maestro+Wireless%C2%AE
http://www.lutron.com/TechnicalDocumentLibrary/030865c.pdf
1-800-523-9466 for technical support
Technical support online appears at page bottom
Normally manuals give you some clue as to how the product works.
The PICO manual says it's easy to control lights (I guess it's easy for mind-readers)
There seems to be no answer or hint when working with the PICO.
I think Lutron tech support is where you go from here.
Let us know what you discover
Oct 22, 2010 | Lutron MRF-VCTX-WH Maestro Wireless White...
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
Hooked up a dimmer switch that is controlled by two locations, and it is not working
I believe you need to get 3-way dimmer set (control and remote) to be able to dim light from two locations.
http://www.lutron.com/CMS400/page.aspx?id=16993#dimmers
Hope that helps.
Mar 05, 2010 | Electric Electrical Supplies
Lutron maestro IR remote control wireless dimmer won't work
http://www.lutron.com/wallboxvideos/maestro_ir_remote_programming.html
If you have followed the programming instructions, the only thing that might be wrong would be the power wire and switch leg wire may be installed on the wrong screws on the back of the device. Be sure that the wire bringing power "INTO" the box is connected to the "Black" screw on the dimmer and the wire going "OUT" to the light fixture is on the "Gold" or "Brass" colored. If these are backwards the dimmer will probably work, but the IR would not. If you are positive it's wired correctly and the IR remote still won't sync up, call the 800 number at the end of the attached video for Lutron Technical Support. Good Luck!
Nov 09, 2009 | Maestro Electrical Supplies
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
Electro Med Services...
