New hard drive for fujitsu GS360-2 desktop?
Hard drive unserviceable.
  • 27,725 Answers
It will depend on whether its a Sata or an Ide for power and data lead connections.
If you can access your hard drive ?
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Hope this helps.
Posted on Dec 10, 2012
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
Missing system operation
Check the hard drive connections. If they are good you could try a new data lead. If even this doesn't work you have a failed hard drive. You will have to replace it and re-install the operating system.
Apr 16, 2013 | Fujitsu AMILO L 6820 desktop memory 256MB...
How to take the hard drive out
on a desktop computer
wear an antistatic earth strap remove the power lead from the power in put on the computer
remove the side panels on on our computer you will see 4 screws 2 either side unscrew these
then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
utube video install a second ide hard drive
Oct 14, 2012 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Do i have to transfer all my hard drive data when installing a new desktop pc
No you don't need too, but you might want to copy all your documents, music and pictures to your new computer.
Jun 12, 2012 | Fujitsu Computers & Internet
I have one hard disk. model number MHK2120AT. i need to make this hard disk as external is that possible
Yes, thats possible, you will need an external usb enclosure such as the one here:
http://cgi.ebay.com/NEW-2-5-SATA-Laptop-Hard-Drive-USB-External-Enclosure-/390241288440?pt=PCC_Drives_Storage_Internal&hash=item5adc3180f8
When you get it, the drive will go in it and then you can plug it in via your USB port on your desktop/laptop.
Regards,
Brandon
Computer Bytes
Dec 10, 2010 | Fujitsu Mobile MHK2120AT 12 GB Hard Drive
MHK2120AT Model number i want to use this hard disk as an external drive
Regards,
Brandon
Computer Bytes
I have just put in new hard drive as old one was to small. It is now saying there are no ethernet drivers. So i cannot connect to internet.
You need to use another computer to go to the fujitsu siemens website.
http://www.fujitsu.com/us/support/
download the drivers for the machine, under desktops.
Then transfer the drivers to the right computer with a usb memory stick or anything else
install the drivers.
Jul 12, 2009 | Fujitsu Siemens SCENIC E600 PC Desktop
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
