Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot camera lens keep going out and in
  • Sony Master
  • 4,738 Answers
The following video provides troubleshooting steps for this problem:
Posted on Dec 13, 2012
  • 4090 Answers
SOURCE: Sony Cybershot dsc-w110 won't turn on ?
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help++++Thyanks for usi9ng FIXYA
Posted on Sep 28, 2009
Testimonial: "Thanks Man.... But before going for compressed air, I blew out some Air from Mouth, and then slapped it against my palm,It Worked,Thanks Man :) ThankU"
welcomejee
  • 10594 Answers
SOURCE: Repair manual Cybershot dsc p200
Click HERE and download service manual of DSC-P200, download all 4 files and unzip with winrar to get pdf manual file.
Hope that will help you.
Posted on Oct 28, 2009
SOURCE: i have a sony cybershot model:DSC-W110 AND WHEN I
bang it on your hand and blow in the lens part with it switched off. worked for me and others
Posted on Dec 06, 2009
  • 11967 Answers
SOURCE: the lens keeps on moving in and out and there a
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 17, 2010
  • 11967 Answers
SOURCE: MY lens doesn't go back in?? says to turn camera
Posted on Jun 18, 2010
My Cybershot Camera vibrates everytime i take a picture.
There are few Sony Cybershot models that vibrate in camera mode, lens mechanism is found defective for that problem. Local camera repair shop will look into lens mechanism and replace wither defective part or complete lens assembly (it depends on model number of camera) to solve the problem.
Thanks.
Mar 02, 2011 | Sony Cameras
I have a sony cybershot w-290. I downloaded pictures to my laptop from the memory stick. When I turn it on I get a message to turn it off and back on again. My lens keeps going in and out. I show full...
Sounds like your lens has issues. Probably some debris/sand got into it or maybe it suffered a
Jolt of some sort. Whatever the case maybe you will need to get your Lens serviced.
Sometimes if you use a case the camera may have turned on inside the case and caused
lens damage.
Feb 02, 2011 | Sony Cybershot Dsc-w290 W230 W220
The lens keeps on moving in and out and there is a sign on the screen to turn off and back on the camera... I have a sony cybershot dsc-w55
I have a cybershot DSC-P5 that was doing this. The plastic ring around the lens that is glued to the casing had become warped. We simply popped it off, brushed/scraped the excess glue away and put the casing back on, now it works fine! Just store it properly and keep an extra eye out for dust coming in where the lens used to be.
Jun 28, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
I have a sony cybershot and the backlight wont turn on
When i turn on my sony cybershot the lens keeps going in and out and it stops and on the screen it says turn off and on again but it doesn't work
Jan 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sep 28, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
My sony cybershot dsc-h3
Symptom shows your DSC-H3 has problem in Lens Mechanism and you need to replace complete lens.
If you want to replace it by yourself, Its part number is as follows...
A-1359-213-A LENS BLOCK ASSY
It is available in Parts Store on $150
Or contact nearest Sony Service Center for replacement.
Oct 12, 2008 | Sony Cybershot DSC-H3 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
