Question about Dodge 2007 Grand Caravan
Replace dodge caravan torque converter
Shudder at 1500 rpm
  • Dodge Master
  • 4,340 Answers
Your vehicle requires a friction additive in the transmission. Install that first and retest.
Posted on Dec 10, 2012
Shuddering on and off when going speeds above 40 mph
did you check your tires then check your tierod ends and let me know what happens
Apr 21, 2014 | 2002 Dodge Grand Caravan
2002 Grand Caravan shudder
you more than likely have a bad solenoid. have a reputable trans shop change out the solenoid pack located on front of trans right behind the cooling fans
Apr 20, 2014 | 2002 Dodge Grand Caravan
Trani/torque convert issue
Sounds like lock-up problem in torque converter circuit. Have them check lock-up on torque converter.
Mar 14, 2014 | Dodge Ram 1500 Cars & Trucks
Jatco 506e
Shudder could be the lockup torque converter if it is an automatic transmission. Another one would be the drive axles. Check the CV joints and u-joint in the drivetrain. If the shudder comes and goes with load changes, it could be either. However, to tell if it is the torque converter, watch the tachometer when the shudder occurs. If the RPM rises slightly, then drops off as the shudder stops, it is the torque converter. There is an additive for this issue that can be purchased an any parts store, called shudder-ease. Hope this helps you.
Oct 24, 2013 | Cars & Trucks
We have a shudder problem at 1500 rpm at about 40 miles per hour
next time it shudders touch the brake pedal slightly,Does it stop shuddering?your torque converter may be bad.
Feb 17, 2013 | 2008 Toyota FJ Cruiser
04 ram 1500 2wd. trans shudder at cruising speeds under 55? Doesn't during acceleration. Change filter and fluid to no avail.
That sounds like a torque converter problem more than likely. It sounds like it's trying to lock up (supposed to do that above 60mph) at a low speed. It will feel like a harsh shift or a shudder when it's trying to engage. Just to make sure I'm correct, drive it and listen to all the gears. When at 55-60mph after it has gone into it's top gear it will normally drop about 200-300rpm when the torque converter locks up.
Jun 07, 2011 | 2004 Dodge Ram 1500
Torque convertor shudder going uphill in my 1992 Dodge Caravan, A604-transmission.
A TC shudder on a 604 is the first sign of the end. You may can get away with putting a torque converter in it , if you do it soon ( tomorrow).If it shudders going up hill it is most likely not the converter since the clutch is released under load. I would suspect and engine miss first.I am constantly dealing with vehicles that someone has diagnosed as a converter shudder and turns out to be something else , most the time just a bad coil or set of plug wires.
Jan 12, 2011 | 1994 Dodge Caravan
Caravan shake when accelerating for 40 - 50 mph ?
In most cases it will be torque converter shudder. The trans fluid is not lubricating properly and causes a less then optimum performance and the lock-up mechanism fails to shift fully. This causes the lock-up to shudder or modulate and gives symptoms of a unbalance wheel at 40-50 mph. Change the fluid and filter and your problems will go away. The fluid should be changed every 30,000 miles...most people don't ever change the fluid and wonder why their trans needs a $3000 fix. Hope it works for you...it did for me.
Dec 16, 2010 | 1996 Dodge Caravan
Transmission light on. Rpm go to 3000 when I'm doing 55mph.it not going into 4th gear (overdrive) what's wrong with my truck?
It seems as though your electronic "lock up" on the torque converter is not actuating. TCC lockup/Torque Converter Clutch lockup.
Oct 05, 2010 | 1996 Dodge Ram 1500 Club Cab
2001 dodge caravan p0700 code
Hello! Well - both of these codes are in reference to shift pack issues. P0700 is related to torque management, designed to reduce the RPM's at highway speed and lock up the torque converter. If it's throwing this code, there is a strong likelihood that the clutch packs are damaged. P0740 is directly related and will most likely result in the need for the clutch packs being replaced. I wish I had better news to report. :(
Hope this helps and good luck!
-KC GTO Dad
Sep 18, 2009 | 2001 Dodge Caravan
Dodge 2007 Grand Caravan Logo
169 people viewed this question
Top Dodge Audio Players & Recorders Experts
Betty Pearl
Betty Pearl
Level 1 Expert
Jeff Brewster
Jeff Brewster
Richard Warren
Richard Warren
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
