Question about Keurig Platinum B70 Coffee Maker
I accidentally plugged my Keurig B70 to a 220 V outlet
It worked until it was ready to brew and suddenly just stopped. I did not smell that something was burned or nor saw smoke.
I would like to know if the unit can still be fixed
  • jason May 11, 2010
    if somone could look at the device that senses the heat from the heating element and turns it off after enough heat is created , then back on when it cools,then with it unplugged and bottom taken off to see heating element and sensor switch , wiggle the connector on the sensor in a side to side motion , to bend the metal a little and free stuck sensor , plug it in before putting it together , to see if it clicks on . fixed mine three times ,third time is lasting for three weeks now , and i make two to three pots a day , constantly running and keeping it hot!
    try that and let me know if that helps , if not then there may be a blown inline fuse under wire protectors
    did that help ?
SOURCE: Keurig B50 Ultra brewer
This is a known problem with the B50 which Keurig will acknowledge if you press them hard. Some users have suggested trying to clean the check valve just inside the water outlet but the best solution is probably to call customer support, complain like crazy, and take the discount on a new machine that they will offer you. Apparently, this problem occurs much more often with the B50 than with more recent models, which may explain why it isn't on the market anymore.
Posted on Jan 23, 2008
SOURCE: will not brew-reads NOT READY
The problem is the water pump has failed. There is a small water pump situated inside the unit right behind where you set the coffee mug. You have to disassemble the outside cover to even get to it. The unit should make a slight humming noise when it first turns on and when dispensing water while making coffee. The noise is the pump refilling the internal reservoir, this is where the heating coil is. We have had three of them fail and each time we were sent a replacement and told to discard of the old unit. Well I kept them for the spare parts, I'm just like that. Well after we got the third one I decided to find out what was really going on with these coffee makers. I took the first one apart, not an easy task I might add, There is a part that is a snapped on part that is not designed to be removed. But with care I got it apart. I started testing all of the electronics and power outputs, which there are may, to see what failed. The heating element, which the service center said was the problem, was not the problem. It worked just fine and no scale buildup. I found that the water pump was not pumping. The lines were getting power, but she no worky… I tested with a meter across the power leads on the pump and nothing. It was shorted out. So I took the second one apart to see what happened to it since it had the same "Not Ready" problem. Well the heating element on this one worked just fine too and no scale buildup. The water pump on this one was defective also, no continuity across the leads. I called the service center and asked if I could order a new pump so I could fix these. I was told they don’t sell parts and that I should not be disassembling the unit, that there were no user serviceable parts inside. I have been searching the Internet for a replacement pump but no luck yet. But that is most likely your problem. A bad water pump. The part number for the pump is , Inversys # CP10-LP / 120V-24W with a duty cycle of 2 min on / 1 min off. If anyone knows where I can get one or two, please post it on this site.
Thanks hope this helps.
Posted on Jan 23, 2009
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 132 Answers
SOURCE: My Keurig B70 at our home in Maine worked fine
sure it need descaling & cleaning
Posted on Jun 07, 2009
  • 7 Answers
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Posted on Mar 29, 2010
Why is my keurig 2.0 K400 (only 1 week old) suddenly stopped brewing? droplets of H2O come out - why?
If you read other questions people have about their Keurig machines you will see that many answers suggest you contact Keurig Customer Service. This is actually the best course to take since they are known to offer a.new machine if the problem can't be fixed.
Feb 15, 2015 | Keurig 2.0 K400 Coffee Brewing System with...
Keurig won't brew
Try pushing a paper clip or dental pic up the spout, the part that pokes into the K-cup, they often plug up.
Oct 18, 2014 | Keurig Coffee Makers & Espresso Machines
Keurig troubleshooting
had the same issue as you do, unplug the unit. I let it sit unplugged for about a minute and then plugged it back in. Suddenly, it appeared to be functioning normally again. The screen indicated the full range of brewing size selections and when I selected my size and hit the brew button, it actually drew water from the reservoir, then it brewed a nice hot cup of water. It's been working fine ever since
Aug 13, 2014 | Keurig Elite B40 Coffee Maker
It does not stop brewing until the whole machine shuts it's self off. also the panel will say not ready yet it is still pouring hot water
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 21, 2011 | Keurig B60 Coffee Maker
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
257 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
