Question about Brother MFC295CNAll-In-One InkJet Printer
Mfc 295 cn machine error af
Into unable af ( machine error af )
Mix-it-up
  • 832 Answers
SOURCE: mfc machine error AF
You have to fix the scanner flatcable on the pcb. Its disconnected :-)
Posted on Sep 25, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
Mix-it-up
  • 832 Answers
SOURCE: error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Posted on Jun 23, 2008
  • 159 Answers
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Posted on Jun 11, 2009
Joed911
  • 4338 Answers
SOURCE: brother mfc 295 cn init
Try this:
1. Press Menu and Black Start
2. Press up arrow 4 times
3. using number pad, enter 80 and press Menu/Set key
4. Press Black Start several times untill the purge count appears on the LCD.
5. enter 2783 using number pad and press Menu/Set key
5. Press Stop/Exit
6. Enter 99 using number tab and press Menu/Set key
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Feb 03, 2011
Unable to Init. AF in brother mfc 64900 cw printer
initial error AF, check the scanner flex cable or any cable, either they are not fix or not intalled properly..
Jan 28, 2014 | Brother MFC-5440CN All-In-One InkJet...
Brother mfc - 295 cn 46 unit unable not printing
Clive's solution worked partially on my MFC295CN. i further erased the number of cleaining cycles and the error message code in the same maintenance mode and it worked. thank you all
Nov 15, 2011 | Brother MFC-440CN InkJet Printer
Unable to Init. 46
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
Error message on my mfc 420 mc
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-240C init. unable AF error message
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Dec 12, 2007 | Brother MFC 240C All-In-One InkJet Printer
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Mfc machine error AF
Sep 25, 2007 | Brother MFC-210C All-In-One Printer
Brother MFC295CNAll-In-One InkJet Printer Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
