Question about Cressi-Sub CressiSub Archimede II 3 Gauge Computer Console
How to get out of gage mode archimede 11
My archimede 11 has gone into gage mode how do you get it back to normai
Why does. My boat sit low in the water when i stop to fish it's. A1989 Cajun. Bass boat??????
physics.
As you go through water at any speed the force of the water flowing/being forced beneath it will cause it to rise in the water. When you are stationary there is no pressure applied to the hull. If your boat carries ballast removing some will mean that it displaces less water and will sit higher in the water when stationary.
Archimededs on water displacement?
http://en.wikipedia.org/wiki/Archimedes%27_principle
Jun 10, 2015 | Boating
What are the application of pascal law , archimedes principle and bernoulli equation
Archimedes' principle indicates that the upward buoyant force that is exerted on a body immersed in a fluid, whether fully or partially submerged, is equal to the weight of the fluid that the body displaces.
Pascal's law or the principle of transmission of fluid-pressure is a principle in fluid mechanics that states that pressure exerted anywhere in a confined incompressible fluid is
transmitted equally in all directions throughout the fluid such that the pressure variations (initial differences) remain the same.
Bernoulli Equation y'+P(x)y=Q(x)y^n
Bernoulli's principle states that for an inviscid flow, an increase in the speed of the fluid occurs simultaneously with a decrease in pressure or a decrease in the fluid's potential energy.
Sep 19, 2013 | Eliminator-Series Fuel Pump EFI or...
Archimedes 550
try your local napa dealer .they have a marine division.
Jul 07, 2013 | Boating
Bought a archimedes 2 secondhand.any idea where i can get a manual?
Hey lehanfourie
try http://cressi.it/easyNews/NewsLeggi.asp?IDnews=17
or http://cressi.it/easyUp/file/instructions/IB_ArchimedeII_2008_en.pdf
cheers
Feb 27, 2011 | Cressi-Sub Cressi Archimede II Wrist...
Check Gages light comes on 99 GMC Surban
one of the gauges must a fluxuated enough to have the computer turn the light on,I've seen mostly gas gauges fluxuate,but train your eye where the voltage is in normal mode because it will still look like the needle is up there but it may only be 11 volts instead of 13-14 volts running.
Dec 07, 2009 | 1999 GMC Jimmy
What is the check gauges light
CHECK GAGES light (1) indicates a potential engine failure(low oil pressure, low coolant, coolant overheating) has occurred.
· Check gages and shut down engine. Gages should read as follows: Oil pressure 5 to 10 psi (34 to 69 kPa) at idle; Water Temp gage below 230 degrees (110 C).
· Check engine oil level (Para 2-11) if OIL PRESS gage indicates low reading. Check coolant level (Para 2-11) if Water Temp gage indicates high reading. Notify Unit Maintenance if levels are low.
If CHECK ENGINE light (2) is on, check engine oil pressure gage (3) and water temperature gage (4). If both indicate normal, proceed with mission and then notify Unit Maintenance. If either one does not indicate normal, stop engine immediately and notify Unit Maintenance
Oct 16, 2009 | 1999 GMC Jimmy
DSR-11 will not record in DV SP mode.
dear, u need to change the memory cell of ur dsr-11 ,
Jul 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Cressi-Sub CressiSub Archimede II 3 Gauge Computer Console Logo
Top Cressi-Sub Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Cressi-Sub Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
