Question about Crown I-TECH 6000 Amplifier
Common Issues with Crown I-TECH 6000 - Crown I-TECH 6000 Amplifier
2 Suggested Answers
fkuk
  • 311 Answers
SOURCE: how much power does a single Crown IT-TECH 6000
http://www.crownaudio.com/pdf/amps/137434.pdf
it varies between what you are playing and how you have wired the speakers
Posted on May 10, 2010
Fuse keeps blowing, tech replaced a 'faulty' battery but it continued. Tech then fixed a 'short in th wiring and still the fuse keeps blowing. Not sure if this is a glitch or an actual problem with just my...
What fuse keeps blowing (drive or hyd HEAVY FUSES or light fuses probs for invertor controller LIGHT FUSES), low batteries or running on discharged batteries for a period of time can blow the fuses. Have the motors been tested? Is the drive an AC and hyd a DC?
Sep 20, 2013 | Crown Walkie Pallet Truck Electric 6000 lb
Crown xti 6000 cuts on then cuts off in 3 seconds of the start up.
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Thank you for using Fixya
Sep 23, 2011 | Crown XTi 6000 2Channel Amplifier
I have a crown Itech 4000 and when I plug it in it the green light around the front power button does not light up and when I turn on the power button on the front only the blue "power" light...
Nice amp. There is a breaker/switch on the back that trips to protect the amp. Turn it off, then back on and see if the green indicator comes back. If the breaker trips again, that's probably an indication of a more serious internal problem.
Nov 09, 2010 | Crown I-TECH 6000 Amplifier
How much power does a single Crown IT-TECH 6000 occupies from power socket
May 10, 2010 | Crown I-TECH 6000 Amplifier
My XTi 2000 is very distorted intermintently. Sometimes the volume drops by at least half. I tap gently on he top of the amp and it comes back up to normal. I heard Crown has had some issues. What's the...
From your description, I would suspect some poor solder connections inside. If you know how to work on these, check for bad connections near the voltage regulators. That is the mode common area.
Dan
Jun 30, 2009 | Crown XTi 2000 2-Channel Amplifier
Had a new battery fitted to my tag 6000 and now 2 of the dials dont reset to zero
To reset the chronograph dials back to zero do the following:
1) Pull the crown out to the position where the date can be adjusted and push the buttons.
2) Pull the crown out to the position where the time can be adjusted and push the buttons.
Jan 06, 2009 | Tag Heuer 6000 WH1312.BA0677 Wrist Watch
TS-6000 Shredder Problem
1800 639 3803 tech solutions service hot line for the ts6000
Aug 18, 2008 | Tech Solution TS-6000 Shredder
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
