Question about HP LaserJet Pro P1102W Printer
LaserJet Pro P1102W pulling paper crooked - HP LaserJet Pro P1102W Printer
5 Suggested Answers
  • 4 Answers
SOURCE: hp laserjet 1320
In the paper path above tray 2, there are 2 pinch rollers that sometimes pop out of place. This can be checked by removed tray 2 and looking underneath where the paper travels. You will see 2 white rollers. They should both be flat against the rubber rollers that they come in contact with. If this is your problem one or both will appear to be crooked or out of position.
Posted on Sep 24, 2008
micromend
  • 748 Answers
SOURCE: Paper Jam that pulls paper to the right and
Hello
You have either a rubber roller that has gone completely bad or more likely there is something still stuck in the printer - probably a piece of paper wrapped around part of the feed roller. Open it up and examine carefully with a flashlight. If you can't find any foreign objects then wipe down all the rubber rollers with denatured alcohol.
Posted on Jul 28, 2009
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Posted on Aug 31, 2009
  • 85 Answers
SOURCE: How to replace 85a print
stand in front of the printer. the printed paper "plate" or "holder" should be expanded. look on left, there is a place to pick up the lid. just pull up with finger.. when you open the top cover you will see the cartridge. grab it through the middle for the handle like plastic and pull gently out. its secured but inside but not very strong. unpack the new cartridge and remove all the orange bands and plastic rings (there is one to protect the chip and one like ring, that will help you to pull out long nailon-like band). gently shake the new cart left-right. then put it in to the printer, it should click securely. close the cover and thats it :)
Posted on Sep 19, 2011
How can i fix 50.0 fuser error on hp printer p1102
pull power out of printer
release fuser unit from back of printer
and check it is not fused together
The fuser unit may may need to be replaced
Jan 27, 2017 | HP LaserJet Pro P1102W Printer
Tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
on Jun 11, 2011 | HEWLETT-PACKARD Hewlett Packard P1102...
Why does the printer beep when printing
to alert the user that their may be sensitive docs printing
Oct 17, 2014 | HP LaserJet Pro P1102W Printer
Prints clean sheet - not printing anything on the paper
mine did that too, no text on page, we had to change the defeat setting from the router.
Mar 20, 2014 | HP LaserJet Pro P1102W Printer
Eror 52.0 scaner eror
The 52 error in most HP printers is not reversible, you must replace the scanner if the is cost worthy.Might want to unplug printer from the power source for 30 minutes and retry, before changing the scanner unit.
Mar 08, 2014 | HEWLETT PACKARD - LASER JETS CE657ABGJ hp...
Reset paper jam error HP P1120w
i have a hp p1102w laser jet, it's about a year old. Hp want 130 replace it, I only paid 100 for it. I have a blinking red light. It tell me paper jam, I can find no Paper that would make the jam. After two day we looked at it again, when we turned it back on it said out of ink. I knew that was no true, because I had just put new ink in it. Now it's back to paper jam. What do I do? Does anyone have any ideas?
Jun 02, 2012 | HP LaserJet Pro P1102W Printer
How to replace 85a print cartridge in new HP LaserJet P1102w ?
Sep 19, 2011 | HP Office Equipment & Supplies
Aug 31, 2009 | HP LaserJet 4L Printer
HP LaserJet Pro P1102W Printer Logo
700 people viewed this question
Seeker5211
Seeker5211
