Question about Tunturi T85 Treadmill
System scheck failed - Tunturi T85 Treadmill
    Top Expert:
  • Tunturi Master
  • 12,223 Answers
adjust the REED switch and speed sensor, test both for open or faulty and replace if necessary+ CLEAN it, tight the plug or connector very well.
see the diagrams attached
God bless you
System scheck failed - 12_10_2012_9_32_15_pm.gif12_10_2012_9_34_58_pm.gif12_10_2012_9_35_19_pm.gif
Posted on Dec 10, 2012
  • 4 Answers
You need new power/circuit board call 07943858686
Posted on Oct 16, 2013
What does code AS mean - seems to be working fine.
Hello marilu scheck - Typically error code AS indicates that a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer and then a professional they suggest to have it repaired.
Oct 03, 2012 | Frigidaire FAD704TDP Dehumidifier
PC will not power up, and power supply is working. The Mother board is in a HP Pavilion a1473W
A few things to check:
Firstly, scheck that there are no blown, or bulging capacitors on the motherboard, this board had a tendency to fail due to these going.
Then, remove all non-essential peripherals and leave only one ram module in the board, try to boot, if it does boot, replace all in turn, booting each time you do so and identify the faulty component.
If it will still not boot, listen for any beeps you may get.. note them down and if there are any, repost your query.
Things to try now:
Remove the cmos battery, leave out for 30 seconds and then replace, try to reboot.
Then try removing all the ram and rebooting with no ram to see if there are any beeps. If it does beep there is the chance that there is still life in the board, if not, the board is probably dead.
Finally, remove the board and power it up on an antistatic surface, using a temporary switch to trip the motherboard pw switch ( or use a screwdriver on the two terminals briefly). If it does power up now, check the switch from the case to the motherboard for breaks or damage, replace / repair and rebuild the tower
Jan 28, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
What would the problem be if my laptop will not turn on?
Battery not charged, problem with the wall plug -- if it is not getting power. It may need resetting -- unplug everything, take out the battery, press the power button and hold for sixty-seconds. Then reconnect and try it. Otherwise it may be an internal problem and need schecking out by an exoensive IT person.
Jul 11, 2010 | HP 6700
In samsung ml-1610 printer horizontally aligned black streaks
scheck the development unit and eny marks on the scanner or exposure glass even on the white plate.
May 28, 2010 | Samsung Office Equipment & Supplies
Systom shuts down when volume is adjusted
These systems have a "power overload" protection circuit. When there is a short, or any defect that causes the unit to draw more current, it will shut down at the source of the power. The problem can be as simple as shorted speaker wires, but it can also be any number of shorted transistors or components in the amplifier stages, hence servicing is required, in those cases. Often, it's the final output power transistors, and you might get lucky and be able to find a replacement if you can identify it with a voltmeter. Other than that, it's the decision to have it serviced or not. Get an estimate, service usually isn't cheap.
Apr 05, 2010 | Denon AVR-3300 Receiver
No tailights dashlights - no fuses blown?
scheck power at the tail lights if there is power They should come on but if there still isnt power check the wiring repair make sure you have a good connection and you can check to see if power is a go at wiring/ Pleas rate my response Thank you very much
Feb 01, 2009 | 2000 Chevrolet Silverado 1500
My driver's window came out of its track. I can't seem to lift the window high enough to clear the track bracket to get it back into place. How do I fix it without doing more damage? I have a 2003 Ford...
tak the dorr trim panel off and scheck wher the run track is for bottom of the dood aand the side run one side may be loose that why its doing this/ Please rrate my response thank you very much
Jan 31, 2009 | 2003 Ford Crown Victoria
Check Engine Light
This is because there is a leak in the muffler and this light indicates increase in oxygen detected by lambda sensor... so nothing serious but you might be injecting little extra fuel causing little decrease in mileage... to fix this just replace or weld the muffler or most probably the flex pipe
Dec 09, 2008 | 1999 Hyundai Accent
Reservoir
Do not overfill your reservoir tank!
Scheck see if your fan is running regularly and strong. If it's not, then cooling won't happen and it will shoot water every time.
Water pumps can also cause such problems in when they fail.
Feb 19, 2008 | Thermaltake Liquid Cooling System Water...
Open Questions:
See all Tunturi T85 Treadmill Questions
Tunturi T85 Treadmill Logo
332 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
