Question about Proform 775 Crosstrainer Treadmill - Free Silver Service Delivery!
Where i must put the safety key at my Centaurus Treadmill belt CF 9010 ??
    Top Expert:
  • Proform Master
  • 12,223 Answers
In the button of the start .
Please download the instr. manual free ,go to
www.fitness.manualsonline.com for free.and see where is located the safety key.
God bless you
Posted on Dec 10, 2012
  • 1 more comment
  • Altin Dec 14, 2012
    Mr.Ernesto Cuadra ! My treadmill is an old model and doesn't have on the console a safety key. So i think that maybe is any reset hole down of the console. I need the manual for this treadmill becouse i bye it from somebody that he haven't the manuals. Can you help me ???
  • Altin Dec 18, 2012
    Is impossible to find the manual from the site fitness.manualsonline for the : Oxide Centaurus CF9010 Treadmill !!!!!!! Is impossible to find the manual generaly...
  • ernesto cuadra
    ernesto cuadra Dec 18, 2012
    go please to www. fitness.manualsonline.com or www.manualslib.com or www. iconservice.com and donwload free
How can I fix my treadmill as it won't run due to Safety Key Lock even when Safety Key is inserted?
Check here for guidance on how replace or repair your safety key:
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-safety-key/
http://www.treadmillsrepair.co.uk/2014/08/treadmill-safety-key.html
Apr 03, 2014 | Nautilus T514 Treadmill
After attaching key all lighs come on but none of the buttons work except foe pulse feature. also belt won't move.
rests the treadmills, follow this steps and fix it. God bless you
replace old batteries ( if your system has batteries, clean the contacts batteries from oxide, dirty, etc) put a new one. Tight the ribbon cable inside the display board+tight the upper and lower connector too.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 18, 2013 | Nordic Track C2255 Console (treadmill)
Treadmill displaying temperature over for an mbh fitness.what are the possible causes?
The cause of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is not lubricate well or needs change. So, first try to lubricate your treadmill belt with silicone oil and be sure that treadmill deck is clean. If the problem continues you must change your treadmill belt.
Greetings from Greece
Oct 18, 2013 | Horizon Fitness Exercise & Fitness
Safety key
Jul 22, 2013 | Merit Fitness 725T Treadmill
I have a centaurus treadmill CF9010 and i don't know where to put the safety key to make a calibration of a treadmill. Can anybody help me pl?
downlod the instr. manual and see how to start. go to
normally the safety key, is in the display board down in the midlle at panel.
God bless you
Dec 10, 2012 | Exercise & Fitness
Two lines appear on the console screen and incline starts going up, then when key is removed all lights go on but nothing works.
I assume you are talking about the safety key. It should have a string attached to it and a clip on the other end of the key's string.
The key is a safety feature and the key should be in the control panel and the clip attached to your shorts or shirt when you are using the treadmill. If you fall of the treadmill, the clip pulls the string and the key is pulled from the panel on the treadmill. This should stop the treadmill instantly by cutting main power to the unit. Main power is shut off because the key is a safety device and it MUST work every time. To help avoid design errors or unreliable stops when the key is pulled, a good designer will shut everything off, not just the motor for the tread belt. I would say your unit was designed by a good design team since everthing goes off when the key is pulled.
From my point of view, it is working as designed unless you are talking about a different key.
I know someone who did not wear their safety key and they slipped on the treadmill, the treadmill threw them into the wall behind the unit and they were stuck with their leg against the treadmill. The belt on the treadmill wore their skin down to the bone on their knee in only a few seconds. Lesson one, keep your treadmill at least 3 feet from the wall. Lesson 2, use the safety key and clip.
-Mark
Jul 17, 2011 | Reebok V 680 Treadmill
I put my key up so no one would get it and misplaced it need another for treadmill to work,can you help please
You get a key that will fit your treadmill in the kit at <a href="http://www.treadmill-world.com/treadmill-accessory-kit.html">Treadmill Accessory Kit</a>
Feb 03, 2011 | RTO Image 15.0R Treadmill Walking Belt
Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Apr 27, 2009 | Proform Sport 1000 Folding Treadmill...
Proform 775 Crosstrainer Treadmill - Free Silver Service Delivery! Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
