Battery led flash when turned off
I wonder why it still flash even turned off?
Good day,
It sounds like you may be putting your laptop into "sleep" mode.
Depending on your operating system installed on your laptop.
Make sure that you Shutdown or Poweroff via your operating system to turn your laptop completely off.
Posted on Dec 10, 2012
  • 1 more comment
  • tengsaman
    tengsaman Dec 11, 2012
    Thanks for quick reply. I have tried turning on and off a few times, but the problem remain. It changed only from yellow to red flash.
  • Craig Perelson Dec 11, 2012
    Could you provide a little more info? What make and model is your laptop? The LED changing colour could indicate that your battery is flat or needs replacing.
  • tengsaman
    tengsaman Apr 25, 2013
    Thanks Craig for your advice. After checking, the pc does need battery replacing. Really appreciate for your help.
My 2004 Ford F1 50 super crew cab truck or not crank and the landline only - flash is really really fast
When you turn the key does nothing happen at all?
Can you hear relays clicking?
Have you got headlights power?
Does the lights on dash come on?
Is the flashing really fast the alarm/immobiliser LED and is there a sequence to the flashing like 5 flashes then a pause?
Jan 02, 2015 | 2000 Ford Focus
Honda xr signal LED lights not flashing
Hi, Anonymous before testing any electrical component in the Light Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries, also before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced your OEM lights with one or all LED lights you are going to need a load equalizer.
If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion.
If all four turn signals flash at the same time like hazard lights even though you only pressed one turn signal button then you have a LED light in the circuit and need a load equalizer that can be purchased from any motorcycle parts supplier.
If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function.
If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction.
If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, the harness connector is usually located under the seat on the front of the rear fender then keep tracing the wiring look for obvious harness damage caused by the rear tire.
If you still can't find the malfunction backtrack from the rear fender wiring harness connector.
If one side does not work you could have a faulty turn signal switch or module check for continuity.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to Make LED turn signals flash
XR650L LED Turn Signal Problem 4Strokes com
MANUAL HONDA XR400
http://www.partsfish.com/page/oem-parts-for-honda
HONDA XR400R Owner Manual
Apr 05, 2014 | 1998 Honda XR 400R
Put led indicators on my yzf1000r thunderace i changed the flasher to an led flasher so it has the correct flash rate but now all the indicators flash at same time ???
Hi, Joshcunningh before testing any electrical component in the Light Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries, also before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced your OEM lights with one or all LED lights you are going to need a load equalizer.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
led signals all flashing at once XJRider com
All 4 turn signals flashing at the same time Suzuki GSX Motorcycle Forums...
Yamaha YZF1000RJ Service Manual
OEM parts for Yamaha
Yamaha YZFR1X Owner Manual
Jul 05, 2011 | Yamaha YZF Thunder ace 1000 R Motorcycles
How do i know when the dvd is charging?
When you first plug it in, the green led should flash for a few seconds. It will then go on solid green while charging. The green led turns off after it thinks the battery is fully charged. Not sure what it does with a defective battery but this is the basic charge sequence.
Apr 07, 2010 | Venturer PVS8380 Player
LaFree Sport Problem - Beeps Twice and LED's Flashing
the matter of beeping is not so serious than the flashing of those LED's every second just get the fuse and the circuit board checked its no self work
Sep 09, 2009 | Electric Bicycle Motor, Bike,electric...
Flashing LED on Samsung SBC-N1 Charger
LED flashing is unable to charge
Sep 05, 2009 | Samsung Cameras
Laptop will not turn on even though LED flashes
Remove the battery and the power cord, wait 5 minutes and put the power cord in and try and start it. If it starts shutdown the machine and try the same test this time put the battery in aswell. If the machine starts fine you will be ok, if it doesn't start with the battery in then you may need to replace the battery.
Jun 09, 2009 | Computers & Internet
Third LED lights up then, turns off and A button doesn't work
Change battery, or by new battery slot thingy and put it in.
Mar 28, 2009 | Microsoft Xbox 360 Controller
Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Jun 03, 2007 | Infinity Reference 611a Car Audio...
Computers & Internet Logo
David Payne
David Payne
