I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is only working .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
  • 27,725 Answers
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Posted on Dec 10, 2012
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
  1. Power your laptop off completely.
  2. Take the battery out of the laptop. Typically the battery is located underneath the laptop towards the top.
  3. Leave the battery out for 30 seconds. This will allow the laptop to refresh itself.
  4. Put the battery back into the laptop.
  5. Power your computer on. Once your computer has rebooted, check to see if the keyboard is working.
  6. Open the "Start" menu on your laptop, if the keyboard is still locked up.
  7. Click on the Control Panel.
  8. Go into the "Accessibility" options.
  9. Open the tab labelled "Keyboard".
  10. Make sure none of the boxes have a check in them. If the laptop has Microsoft Vista as the operating system, go to the "Ease of Access" option and go to "Change how your keyboard works." Make sure none of the boxes in that section are checked.
  11. Click the "Save" button.
  12. Exit the Control Panel and begin typing to see if the keyboard is now working.
Posted on Nov 29, 2014
listeur
  • 88 Answers
SOURCE: keyboard and touch pad locked
reboot- if that does not work the keyboard/touchpad may be disconnected or bad. ram is under an access panel on the bottom in the middle- you need a small screwdriver to add ram (ddr)
Posted on Nov 24, 2007
How do I unlock key board and touch pad.
Posted on Sep 27, 2008
SOURCE: How can I unlock the blue function keys on my HP Pavilion dv2000?
Hi, I had the same problem and found the solution on another website:
To turn on and off Bilingual blue keys:
Hit Ctrl + Shift + shift
(yes, both shift keys at the same time in addition to ctrl)
and that turns on and off the Canadian bilingual blue keys on HP lap tops.
It's so annoying and happens to me frequently. Hope this helps.
M
Posted on Dec 15, 2008
Murphybanton
  • 2004 Answers
SOURCE: HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
Posted on Apr 10, 2009
bob_computer
  • 3153 Answers
SOURCE: the keyboard has a keypad, but when y turn on the
Sorry but you found what is NORMAL for laptops. this is not a bug, error, fault, etc.
It does exactly what it is supposed to do even though it may have a proper number pad too. leave num lock off
Posted on Aug 09, 2009
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Fn+num lk not working
There is no standard meaning to any Fn +Fx key combinations. It depends on the manufacturer and the laptop model.
Usually the Fn key works in combination with the Function (Fn) keys F1-F12, and maybe ESC.
In my Toshiba, there is an overlaid numeric pad that can be activated by pressing Fn +F11. Once the sequence is pressed the F11 key led remains lit, and the overlay active. Pressing the F11 key restores the normal keyboard. Fn+Num Lock does not do anything.
Please check you laptop's manual to familiarize yourself with the uses of the Fn key on YOUR computer.
Dec 19, 2013 | ASUS Eee PC 1000H Laptop
Numeric key pad on right wont work on aspire 7741 notebook
Maybe you need to press the Num lk (number lock) key at the top of the keyboard, then Press and Hold the FN function key at the lower left portion of the keyboard then hit the number key you want..
May 06, 2012 | Acer Aspire 7741z
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
Daughter touched keypad.
Go into control panal
than clic key board
go int0 properties
Apr 23, 2010 | Fujitsu AMILO PC Laptops
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Computers & Internet Logo
707 people viewed this question
David Payne
David Payne
