Question about E-Machines eMachines Desktop PC
I hear 4 beeps ever 5 minutes on my emachine et1331g
SYSTEM BOOTS UP WITH NO ISSUES....OPERATING FINE....BUT AS OF TODAY....IM STARTING TO HEAR 4 BEEPS EVER 5 MINUTES...REBOOTED SYSTEM.....SAME ISSUE....AGAIN...SYSTEM IS FUNCTONING OK AS OF NOW....WHAT COULD THIS BE
  • 242 Answers
That is somewhat odd. I don't think that I've personally heard of that happening before. Question: What is the date/time on your computer? I ask this as I believe that your issue may have to do with the little battery on the motherboard.
If the date/time on your computer gets reset every time you turn on the machine then you'll want to replace the little battery on the motherboard.
Posted on Dec 10, 2012
eagle338
  • 4889 Answers
SOURCE: Emachine wont start, just beeps
This is probably a problem with your DIMM(RAM) Did u recently install an extra RAM?If yes then remove it because the beep sound is due to the mismatch of frequency of two DIMM's. If not open your computer and check if the DIMM is loose just push it in and powerup your comp..Let me know if its fixed..
Posted on Oct 08, 2007
knotbeerdan
  • 413 Answers
SOURCE: Beeps when starting up
I need to know how many time it beeps. THat actually tells you what is wrong. This site tells you what to listen for. Let me know if you need any interpretation
Posted on Dec 29, 2008
mindreader
  • 578 Answers
SOURCE: on boot up the emachine now beeps every 5 seconds
Reboot with "F8" held down.
you are only booting to bios and minimum disk software. This may give you an indication of your monitor or video driver status.
If you can borrow another monitor from someone, that would confirm your monitors status....
Posted on Oct 14, 2009
  • 11 Answers
SOURCE: emachine T5062 pc wont turn on, I get 5 beeps When
make sure it is not getting really hot, also try cleaning all again and start putting them together step by step. make sure the dust didn't got in another part like RAM memories slots, and if you have a big problem with the processor the PC wouldn't even start, wont even turn on.
Posted on Nov 15, 2009
Combchris
  • 64 Answers
SOURCE: emachine starts boot process but stalls, no beeps
most likeley if you see something on the screen but it wont boot it is a mem problem, does it load bios, if so it is prob not memory
Posted on Nov 18, 2009
Beeping sound when starting
Usually when you first turn the power on ... it's usual to hear a couple of beeping sounds . And then, you may hear whirling/clicking sounds when your disk starts up (rotating) and your CD/DVD drive starts up, etc.. Then the monitor/screen lights up and starts to show the operating system (e.g. Windows) panel ... as it starts up.
If your system just beeps ... and beeps ... and beeps... and nothing else happens, the screen doesn't light up and show anything (for a few minutes), it likely the system is not starting up properly.
If you can clarify what actually happens, maybe I can offer more suggestions/information to help.
Apr 03, 2014 | Computers & Internet
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
The computer isn't coming on the power cable is plugged in the green light is blinking but nothing else is happening
Do you hear fan starting noise? If you dont hear any noise most probably you need new power supply.
you can buy cheap power supply from www.aria.co.uk
if you hear the fan noise!
Does you motherboard starting with POST (a beep noise).
if you dont hear. well you need a new motherboard which should be compatible with your other peripherals.
if you hear a beep noise! Most probably your operating system is corrupted. (Boot file corrupted)
in this case you may have to install new operating system.
Thank you
if you got any problem let me know
somindradilruk@gmail.com
Sep 03, 2010 | HP Pavilion a705w PC Desktop
Emachine D2880 worked fine yesterday will not power on today
when you push the power button, fan or blower on power supply spinning or not? of not. your problem is power supply, nut if yes... did you hear any beeping sounds?
Jun 19, 2010 | E-Machines eMachines Desktop PC
Playstation Update was interrupted. Now when PS3 is turned on i won't load the main menu stays on the wavy line screen
you can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
Step 4
: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Oct 06, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 will not load up the green light comes on but nothing happen a few minutes later it says 'cannot start correct hard disk was not found' can anyone help on how to fix or how to recover my...
Try this, but keep in mind that one of the options wipes all your data.
These should be safe to use, and 'should' keep your data.
  • Restore Default Settings
  • Restore File System
  • Rebuild Database
  • Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    Step 3:
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    3. Rebuild Database
    Oct 04, 2009 | Sony Video Game Consoles & Games
    I have a code 88 -What is the problem has ben 48 hours
    This is an added extra and basically a new problem. Mine is brand new. I hold the left button down, and get the first beep, then hold the right button down, and it beeps multiple times, and stayes at 88. It took about 15-20 minutes of trying this before we got the 00. I think the lock mechanism is broken, as I can't get it locked either at the end, so I just let the system lock itself after 1 minute. We unplugged it and tried again, and still after multple time eventually got it to go to 00. I take it that this isn't normal.
    Jun 22, 2009 | Intex Automatic Salt Water System for ...
    4 beeps oi ho dc7800 PC
    4 Beeps: System timer failure
    Explanation: There is a problem with one or more of the timers used by the system to control functions on the motherboard.
    Diagnosis: This is usually a motherboard failure.
    Time for new computer.
    Jan 11, 2009 | HP RT935UAABA - HP Compaq dc7800...
    Phone not ringing
    Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
    Dec 26, 2007 | Vtech VT-9118 Cordless Phone
    E-Machines eMachines Desktop PC Logo
    49 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
