Question about Encore ENH908-NWY-A 8-Port Nway Switch
Theres an ip address conflict when i use my 8 port NWAY switch
My two computer will not function because theres an ip address conflict
  • Salvador Blanco Dec 12, 2012
    very helpful. Thanks a lot. may your tribe increase more.
  • 2,878 Answers
You need a router to use the hub or switch. It provides the IP routing. Make sure the Router is set DHCP. If you have all this correctly setup then try:
Go to Start > Search (Run in XP) and type cmd and hit ENTER. In the command prompt type ipconfig /release and hit ENTER. Then type ipconfig /renew ENTER. This just refreshes your IP. Test it.
Posted on Dec 10, 2012
Why Addresses in the IP Address Pool on a Switch Are Exhausted When the Switch Functions as a DHCP Server and It Has a Few Clients?
If the IP address pool has much more resources than needs of clients, the following two reasons may cause address exhaustion:
1. An attacker keeps changing the CHADDR field and sending DHCP Discover packets to exhaust addresses. If so, contact Huawei engineers to deploy DHCP snooping to protect the IP address pool.
2. The DHCP server ping function is enabled on the DHCP server. This function tries to ping the allocated addresses before responding to DHCP Offer packets. If a client responds to any ping packet, the DHCP server considers that there are address conflicts and addresses are exhausted. To solve this problem, two methods are available:
1. Capture packets on the ports connected to the DHCP server. If a client responds to ping packets, prohibit the client.
2. Disable the DHCP server ping function using the undo dhcp server ping packet command.
3. Such as S5700, S6700
Aug 01, 2016 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
on Dec 06, 2009 | Computers & Internet
D link des 800d switch configure ip addess for 2 computers on a network
D-Link DES-1008D 8-Port Ethernet switch is unmanaged switch which can only support 10/100 MBPS.The DES-1008D is a passive switch which means there is no way to configure the ip address and no need to.
Jun 30, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
I have a 8 port ethernet switch DES-1108 how do i connect it to a DSL cable modem and the 3 computers i have . do i need to use the router still. or what
If the computers only need to communicate with each other then you do not need a router.
Each of the computers must have the same Network name (workgroup) and have the same IP address range. If you have a fixed IP address on each of the computers the IP address range should be the same - for example 192.168.3.xxx (xxx being a number unique to each of the computers, BUT the first 3 group of numbers (IP address range) MUST be the same on all the computers.
If the computers need Internet access then a router is required and if there is insufficient LAN ports on the router then you need to add a network hub connect the router to tht hub and connect the computers to this hub. You would need to configure the computers to obtail an IP address automatically, the router will issue IP address to the computers automatically.
I would not recommend using the Ethernet switch with the router as it would require a more complex configuration.
May 13, 2011 | D-Link DES-1108 8-Port Ethernet Switch...
Unable to get IP address
The D-link DSS switch should require nothing special to pass along IP addresses. You may want to power off your computer, switch and router, and then power up after 30 seconds. It could be that when you were testing, the computer pulled an IP address from the router and if you moved to the switch without renewing the IP, there was a conflict. Powering down and repowering should do the trick.
Apr 13, 2010 | D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps...
Cannot get ip through D-Link DGS-1008D Green switch
Your question is a little odd, as you should not be dealing with ip addresses when referring to a switch. Is the devices only function as a switch? Is it powered on? Are the ports enabled? Please clarify what you are trying to do when you "don't get ip addresses through"
Jul 05, 2009 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Router problems
Did you validate the IP addresses for each computer? Issue the "ipconfig" command on each and compare the IP addresses. You may have a conflict. I would clear any port forwarding settings first
Jul 29, 2007 | Belkin (F5D5231-4) Router
Encore ENH908-NWY-A 8-Port Nway Switch Logo
135 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
