Box reads noCP during bootup - Televison & Video
  • David Rivera Dec 10, 2012
    Thanks SDTech. I tried it but to no avail.I think the box is ng because even without the cable being hooked up, I still get the same error code on the led display. Thanks for your help, much appreciative.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
What kind of box: cable or sat or other?
Posted on Dec 10, 2012
Testimonial: "Sd tech responded very quickly. Thank you.Now lets see if a solution can be found."
  • 2 more comments
    Thanks for responding. The box is scientific atlanta explorer 4250 hdc.I have Brighthouse cable in Lakeland Fl the box starts to boot up but then I get "noCP" on the led window panel on the box.I tried connecting and disconnecting the hdmi cable but still ng. Thanks again.
  • SD Tech
    SD Tech Dec 10, 2012
    try removing the HDMI cable, power removed from set and box--wait several minutes and connect HDMI back first and then power to the units--HDMI DOES NOT LIKE CONNECTIONS BEING MADE IF UNITS ARE POWERER OR EVEN PLUGGED TO POWER. O
    Ok I tried it, but still same error code on led display.I called Brighthouse and they said the box is probably NG. Thanks for your help.
  • SD Tech
    SD Tech Dec 11, 2012
    hope it works out and happy holidays to you.
Chipset heat up while bootup
ur sata/pata drives are gone bad.try to replacing the drives
Apr 28, 2014 | ASUS Computers & Internet
How do i install my lg bh16 driver in windows 8
You don't...... installation of the drive and it's support are handled automatically by the OS during bootup. This support will only allow it to read data or music disks. For other applications you will need compatible dvd decoding and burning software. Is the drive listed in My Computer?
Sep 13, 2013 | Computers & Internet
When i connect a pen drive to the usb port of my G31D M7 mainboard,a dialog box pops up,showing, ' This device can perform faster on connecting to a high speed usb port'. So i downloaded the usb...
If you're comfortable having a look at your BIOS screens, then have a look for an entry mentioning USB 2.0. See if it is enabled. If it isn't, enable it, save changes, and reboot.
You can usually get into BIOS by tapping the Delete key on your keyboard during bootup, but some motherboard manufacturers have different ones. Just read on the screen during boot up what button to look for.
Hope that helps.
Cheers from NZ
May 09, 2011 | Biostar Computers & Internet
When the laptop is switched on it goes to the page with start windows normally. when i select it, it goes to the starting page of window xp and then restarts again.
I would suspect damage to the file system and possibly something wrong with your hard drive. Windows loads a number of system files during bootup, and when it cannot find or read these files, it will cause Windows to repeat the process and cause the bootup loop that you are having.
First thing, backup all your data if possible. Second, you can try pressing F8 when booting the computer to access the "safe mode" boot menu. Once in the "safe mode" boot menu, select the option "Last good configuration", and see if the computer boots up.
There are more complicated methods if that does not work, but its the first thing I would try.
Mar 02, 2011 | Compal EL81 Notebook
Was connected to computer during shutdown and bootup. Stays on doesnt shut off, no functions
Hi jeff,
I'm afraid most mp3 players warn against keeping the player connected during shutdown and bootup. Your player seems to be in the same state. You could try resetting it (only if you know how to - this could be dangerous) - but don't worry, no data would be erased if you do it right. Otherwise you can take it to a service center and see if they have any suggestions, maybe like formatting.
Nov 02, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
How to hide or eliminate boot selection on Acer Veriton s460...there wasn't any security selection in the computer BIOS?? thanks
Login to window,,
Go to start --> Run --> type there msconfig
this will open a window, now inthat go to Boot Tab
And check if the two option given, if you have multiboot operating system (Viz Win 2000 and other one Win Xp)
Then it will show you each time during bootup (you can only setup one as default)
You also can setup the time for it to take in bootup.
Let me know if you need further help
Ellin
Oct 15, 2008 | Acer Computers & Internet
Turn on, after intital screen with setup options the following appears: "SMART Failure Predicted on Hard Disk 4: SAMSUNG HM121HI - (S1) WARNING: Immediately back-up our date ....... Afailure may be...
Have you installed or attached any Software /Device since then.
Please unlug any device attached and then try. Also try tapping F8 key during bootup.
Check BIOS with F2, DEL or ESC key during Bootup.
Best of Luck & Regards Puneet
Oct 05, 2008 | HP Computers & Internet
Sony pcg-fx140 bootup problem
1. check bios for first boot option to hard drive.
2. If xp, run repair from cd (enable cd boot in bios).
Jul 03, 2008 | Sony MBX-49 ASSY Motherboard
Televison & Video Logo
434 people viewed this question
Top Televison & Video Experts
Electro Med Services...
