Simpletech 160 Portable doesn't show up
The harddrive worked fine on my laptop. On the desktop, it at first looked for hardware. The harddrive never showed up. I tried different usb ports. It doesn't show up in Computer Management.
THanks
Carl BUFFALO MINISTATION
    Sergeant:
  • 270 Answers
Because it is not properly connected.connect it well.
Posted on Jan 13, 2009
I am not able tp acces files on my simpletech 120 GB as this drive is not recognized both on my laptop and desktop
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 09, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
All my files on simpletech harddrive show as 0
you mean you HDD does not show the capacity it holds? try using it on another pc, or even try using it on your friends pc, see if it works?
Mar 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Data on my Simpletech 160GB is gone...?
Take the drive out and put it in a new external case. the copying may have been caused by a virus in the computer.
Nov 24, 2008 | SimpleTech 160GB USB 2.0 / FireWire...
My portable harddrive fell from a low table
i am afraid that the drive has gone, but you could try to fix it using disk manager application.
Nov 17, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Jan 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech hard drive
Your desktop usb compatibility is not supported your 160GB. The only way to attach you 160GB is to make it secondary partition to your primary drive by opening the CPU and attach it to your IDE cable.
Don't force yourself if you cannot do it by yourself just leave it to the expert. Probable cause to damage your hard drive if it is not installed properly.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 29, 2007 | SimpleTech 160GB USB 2.0 / FireWire...
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
