Question about Hitachi 50V720 Television
Where is th cooling fan located on model 60vs810
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
It likely has more than one, the main fan should be right at the lamp inside and another should be on the digital board, most of these have at least two fans, got some issue?
Posted on Dec 10, 2012
Where is the position of radiator fan relay on jeep liberty 2006
no idea to be honest earlier jeeps had then at the front of the wing down below as i remember ?? newer one would i imagine be in the electrical box under the bonnet near the battery
Dec 02, 2016 | Jeep Cars & Trucks
I have a TH-M50HD18 PANASONIC PLASMA (18 months old) that becomes extremely hot to the touch after being on for only 30 minutes. (So hot that everyone I have asked to touch it for their opinion, jump back...
Check whether the cooling fans have stooped. Might be. If you wish to get more details about the positions of cooling fans inside, check the site linked here. http://electronicshelponline.blogspot.com/ It has disassembly procedure to this TV, which will describe all about it.
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 25, 2013 | Panasonic TH-50PHD3U 50 in. Television
We have a Hotpoint microwave model no. RVM15135DM2WW. It works well for about 2 minutes at a time then shuts down. Sometimes a PF will appear on the screen. I'm assuming it's overheating. Th
see the steps and use the common sense:
God bless you
All microwaves have some sort of a cooling fan to help keep the magnetron and controls at a tolerable level. Most OTR models will usually use the vent motor for the cooling fan also. Countertop units have a small fan behind the control panel somewhere. Either way, if the cooling fan is not working and heat builds up, it is going to open a thermostat. On some makes, this thermostat might re-set itself as soon as the temperature cools down. Other makes, you will have to replace the thermostat or fuse.
If this is your microwave oven repair problem, you will need to check the operation of the fan. Below in the component testing chart, you will see how to test the fan. Also, if possible, make sure the fan is not obstructed somehow and not turning. Also check your fan relay at your control board for voltage, if no voltage, replace control board. This fan should come on at the same time any cooking starts.
Sep 09, 2012 | Microwave Ovens
How a cooling fan should work
The cooling fan is thermostatically controlled and enerised once the radiator/engine temperature exceeds that of the thermostat controlling th the fan. If the fan is coming on prior to the engine reching the operational temperature, then either the thermostat is not functioning or ha been wired incorrectly into the system the radiator was changed.`
Jun 09, 2012 | 2001 Toyota Camry
Yesterday my 1988 cadillac eldorado's engine got very hot, even though it didn't overheat and all the fluids are fine including the antifreeze. I only drove around 10 miles. Do you know what might...
DOSE IT HAVE ELEC FAN MOTOR OR MECH FAN IF ELEC ITS THE SENSOR TO TURN TH FAN ON CAN BE JUMPED OUT INCASE OF EMERGENCY IFF MECH FAN NEED THERMOSTAT
Jul 28, 2011 | 1988 Cadillac Eldorado
2002 jeep grand cherokee larado is over heating. The cooling fanonly runs if I hotwire it. I changed th thermostat. Temp gauge is reading . Could it be the cooling fan relay if so where is it located. The...
Fan relay is located under pass headlight. Remove light assembly, use 2 1/2 " hole saw to drill hole in plastic housing ,3"from back wall, 3'' from left side.This will put you right over relay. Unscrew two bolts,replace. Relay was $40.... dealer wanted$350 to remove front bumper to replace it.
Sep 02, 2010 | 2002 Jeep Grand Cherokee
1999 Dodge caravan 3.3L motor. problem: Cooling
the fan should only come on if a/c high pressure is above 200-250psi. or th eeng is HOT +220f... the relay I think is located at the lower left corner of core support, and common to fail.
Jun 14, 2010 | Cars & Trucks
Cooling fan switch/or sensor
The Coolant temp Sensor is located right under the top radiator hose (on the engine side), with a little black connector!, You might have to remove th etop hose to get to it with a deep socket and extension!.
Also Dont Forget to blled the coolant system by the bleeder valve uptop right near/above the coolant sensor!.(10MM Mini socket w/ extension IIRC!)
Jun 03, 2009 | 2002 Chrysler 300M
Hitachi 50V720 Television Logo
69 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
