Laptop Screen Shows vertical Red lines on Grey Color on random Spots
I see vertical red line(s) on random spots, whenever some dark grey color appears on screen, there is not any fixed spot but it shows on random places, some time one line and some time 4-5. Please help
  • 1 more comment
  • ataur_rah724
    ataur_rah724 Dec 12, 2012
    This is an standard answer for some Desktop...but I am using a Sony Vaio Laptop...trid to reinstall the Graphics driver but no luck...attached external Monitor but there is no red/pink line on that monitor....now some time I see more than 1 line on screen...laptop is out of warranty..warranty expired last month.
  • Brian Sullivan
    Brian Sullivan Dec 12, 2012
    sony vaio are proned for lcd problems you might be up for a new lcd sunshine
  • Brian Sullivan
    Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards.Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems.
  • 27,725 Answers
Check the cables. It might be overly simplistic, but if your monitor is connected via a serial cable, one of the pins might be bent or missing. This can cause slight display problems, including a vertical line. If you are using a USB, try another cable and see if the problem persists. Update your video card driver. Some discrete cards have an update feature in the properties window for the device. Right-click on your video card in the programs list, and select "Properties." The update will be a button under the "Drivers" tab if your device is so equipped. If not, visit the manufacturer's website and search for the most current driver for your model number.
Updated video drivers could solve the problem. Place a box fan directly behind your computers intake vent for extra cooling. Sometimes if there are system problems, your components can run too hot. If cooling the computer takes away the line, you know have you an overheating problem, not a monitor problem. You might try cleaning the internals with canned air. Remove the housing, and thoroughly blow any dust, hair or carpet fiber away from the fan and off the mother board. While you're there, you can check to see if there are any obvious loose connections. Connect the monitor to another computer if you have one available. This is probably the most definitive test of your monitor's health. If you have a line when the monitor is connected to a different machine, it's likely time for a new monitor. As frustrating as it sounds, taking apart one of today's monitors in an attempt to repair it is more expensive than buying a replacement. If you don't have another computer available, try shutting down the computer but leave the power on to the monitor. Using the buttons on the monitor bezel (if you have them), call up the settings. If the line appears in the menu just as it did in the video from your computer, then you definitely have a monitor problem. Replacement is probably in order
Posted on Dec 10, 2012
  • 16 Answers
SOURCE: black/GREY screen with light spots screen
Try reinstalling the gpu driver. If the problem still persists, the screen may be going out.
Posted on Apr 17, 2008
epr1977
  • 46 Answers
SOURCE: black screen with horizontal green lines
Hello yoyoxide.
from my experience can be something related with the video card. I recommend you the followig (Hardware diagnostics):
-Look for one of the discs that came with your computer, it should say (Drivers & utilities).
-Boot from the CD. If you don't know how to do it do the following:
1.Insert the Drivers&Utilities Disk.
2.Restart teh computer.
3. When you get the Dell logo, press F12
4.Select Boot from CD/CDRW-DVD (something like that).
-You will get a prompt to run the diagnosics.
-Just follow the wizard
-I recommend you to run diagnostics for everything.
-You will see if you have any problems with your hardware.
It seems that you have a pretty new laptop, so probably it's under warranty.
Posted on Jun 28, 2008
SOURCE: Vertical lines in my laptop screen
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Posted on Sep 24, 2008
Niraj Limbu
  • 183 Answers
SOURCE: display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
thanks
Posted on Dec 27, 2008
  • 16 Answers
SOURCE: my laptop screen shows red,green, blue, yellow
Asides from purchasing and installing a new LCD screen you could try reseating the connectors.
Posted on Sep 11, 2009
Colored spots on Samsung HLP5063W
The color wheel or the DLP chip itself will cause this. Parts can be had here: www.shopjimmy.com
Jun 27, 2017 | Samsung HL-P5063W 50" Rear Projection HDTV
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
I am getting black spots (short black or grey lines) on clothing. The spots appear to be random. Maytag Model DE412
You left something in a pocket that melted in the heat and left those spots and lines. You will need to clean the inside of the drum thoroughly. Without knowing the source of the spot and lines, I can't tell you how to remove them without damaging the clothing.
Jim Hart
Jun 14, 2010 | Dryers
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
My iphone's screen is white with vertical stripes
try to restore ur fone manually.
that should work
Dec 29, 2008 | Apple iPhone Smartphone
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Red spots and Lines on Laptop
the screen might of got wet
Jan 04, 2008 | Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
