Question about Ascaso Dream Espresso Machine
The water pump for my Ascaso Dream isnt working. A very loud obnoxious noise is being made everytime we turn it on, but no water is getting through.
  • Anonymous Feb 09, 2009
    The water pump starts working and, after few seconds, it fades, it loses power and brews only few drops. I have cleaned my machine, "purged" it and it does not improve. It only brews when it has no coffee in it.
  • GenuineIngenuity Feb 29, 2012
    I had a similar problem and was able to fix it. First, try the 'priming' method described in the manual. If that doesn't work, try the below steps and then repeat the priming method.
    1) Remove the filter from the end of the tube in the water tank
    2) Insert the tube into the nozzle cap of a drinking water bottle (must be a tight enough fit not to leak)
    3) fill the bottle half-way and attach the cap
    4) hold the bottle up as high as the tube will allow (without kinking the tube)
    5) squeeze water into the tube and release
    6) if a bubble appears at the machine end of the tube, tap the tube until the bubble has risen into the bottle
    7) repeat steps 5 and 6 until no more bubbles appear
    Now try to prime the pump (open the steam valve and run the pump until 1/2 cup of water comes out of the steam nozzle).
    It worked for me... no guarantees that it will work for you.
Try the priming method described in the manual first.
If that doesn't work... the method below worked for me after my Dream was in storage for a year and had been shipped around a bit.
1) attach a water bottle to the tube in the water tank (you may have to remove the filter) - get a good tight seal and fill the bottle about half full with clean water2) hold the bottle up as high as the tube allows, without kinking the tube3) squeeze the bottle gently (there will be some resistance) so that water goes into the tube, and release4) a bubble will probably appear at the machine end of the tube - tap the tube until the bubble has risen into the bottle5) repeat 3 and 4 until no more bubbles appear6) remove the bottle and replace the water tank and tube filter7) prime the pump again (open the steam valve and run the pump to get 1/2 cup of water from the steam nozzle)8) make some coffee. Or, this might be a good time to descale...
Posted on Feb 29, 2012
    Scholar:
  • 36 Answers
It does sound like the pump. If it isn't sucking any water up and it is very noisy then it is def the pump. I can get these for you if you are still looking.
All the best
LaPavoniBoy
Posted on May 28, 2009
Won't turn on
Hi Sab, you need to replace the thermal fuse on the ascaso dream. Ascaso dream safety fuse
Mar 17, 2014 | Ascaso Dream Espresso Machine
I purchased an Ascaso Dream espresso machine on ebay without reading the fine print that it was not working by not heating up. Is it merely the heating unit/part that needs to be replaced? Also it only...
If when you switch on the machine and the water is cold then, you should replace the boiler element.
There are a number of ascaso boiler elements, depending on the year. Dream Arc Basic Ellipse Page 2
It it works and you get steam , then the boiler is fine.
It may be that wires are loose inside?
Mar 05, 2014 | Ascaso Dream Espresso Machine
Ascaso dream is not pumping water
If you can hear the pump running, I would say you have some blockage in the line
Apr 12, 2013 | Ascaso Dream Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Ascaso Dream Leaking Water
Correct, inside the grouphead their is a gasket which is the same diameter as the filterholter which make the perfect fit so the presure of the water will not leak out. So now either the gasket is damage in one point so you have the leak from that point. Second the gasket have become hard so it can not make perfect fit with filter holder. In both above case you have to replace the gasket. Finally their is aposibility that the gasket is dirty with coffee remains and again we can not have a perfect fit. You can use a hard brash with the water running so you can clean the gasket.
With this case you can unsrew also the shower from the grouphead and clean it also for better coffe results
May 05, 2010 | Ascaso Dream Espresso Machine
Ascaso Dream water leak & bad shots
Hi
Sounds like you have a leak in the system. If your handy, you can remove the top. Remove everything. Water tank included. Unplug the machine. Now turn the machine upside down on a towel. There are 2 screws behind the brew head. Remove them, then lift the machine off the top and set it right side up. Now you can see the inside of the machine where the boiler is. Do not touch anything inside the machine. Replace everything and plug the machine in. Now turn the machine on and try to make a shot the same way. This should show you where your trouble is. Once you see where the trouble is, unplug the machine. Contact seattlecoffeegear.com, or 1st-line.com. They can help.
Jul 29, 2009 | Ascaso Dream Espresso Machine
Ascaso, Innova, Dream Heater not working
If you are confident that your heating element is dead and are filling adventurous enough to replace it- you can get one at:
http://www.1st-line.net/cgi-bin/category.cgi?category=review&item=i365&type=store
I saved myself shipping and repair costs by having it replaced by a friend. He took pictures and marked wires & connectors before removing the broken heater.
Yeah,, this looks to be systematic failure with this machine. Very disappointing- for this kind of money, one would expect the machine to work a bit longer after warranty expires.
Oct 18, 2008 | Ascaso Dream Espresso Machine
Ascaso Dream Espresso Machine Logo
991 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
