Question about HP Deskjet F4180 All In One Inkjet Printer Cb584a
My printer is printing very slow
When printing a page it prints a little then stops and then a little and stops until completed
  • capt_kurto
    capt_kurto Dec 10, 2012
  • 242 Answers
Are you printing images or text? Your printer, what you are printing, and the paper you are using may each contribute to this effect. Try the following instructions and see if you can change the print quality and paper type to something that prints more quickly.
To select a print speed or quality
  1. Make sure you have paper loaded in the input tray.
  2. On the File menu in your software application, click Print.
  3. Make sure the HP All-in-One is the selected printer.
  4. Click the button that opens the Properties dialog box.
  5. Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
  6. Click the Features tab.
  7. In the Print Quality drop-down list, select the appropriate quality setting for your project.
  8. NOTE: To view the maximum dpi that the HP All-in-One will print, click Resolution.
  9. In the Paper Type drop-down list, select the type of paper that you have loaded.
Posted on Dec 10, 2012
How do I fix my printer?
throw it in bin
check you pc memory also
May 05, 2016 | Office Equipment & Supplies
Slow printing
Remove both cartridges, switch off printer and then on. After cartridge holder comes to the center install both the cartridges. Then it will print the Alignment page. After alignment page prints place the Alignment page on to the scanner and press SCAN button as mentioned in the Alignment page. After completing the scan try printing. It will print the usual speed.
Note: For the alignment process both cartridges should in good working state
Jan 24, 2013 | HP DeskJet F380 All-In-One Printer
Printing test page at startup
Hi Monica,
You should have replaced new ink cartridges recently and since from that the printer must be printing Alignment test sheet. It means that you have not completed the alignment test.
Please follow below step to complete the test
  1. Turn the printer OFF and then ON, allow the printer to print the test page.
  2. Place the test page correctly on the scanner flatbed and press the scan button.
  3. Now the printer ON light will start blinking.
  4. Wait until the power light stops flashing.
  5. Now the test is complete and test the printer again by powering off and on.
Regards
Riztech
If this solution is helpful,kindly vote 'thumbs up' and testimonial.
Dec 31, 2010 | HP PSC 1315 All-In-One InkJet Printer
Unable to Cancel Documents in a Print Run
if you want to stop a print run simply press the stop button on the printer
next go to the control panel and get to the add a printer section
click on the printer and open up see what is printing
highlight all in the print queue and delete it there no print queue , nothing to print
to be sure and not waste paper remove all but 1 sheet and press the start button
keep using that paper until what is spooled in the printer memory has been used
Mar 24, 2017 | Canon BJC 4400 InkJet Printer
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer realigns print head
hmmm..that's a little weird...does this happen with a test print page too?
Mar 27, 2008 | Office Equipment & Supplies
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC1350 All-In-One Printer
This printer prints at a really slow 1.4 PPM, and if it's doing that, it means that the buffer in the printer is full and it must print what it has in memory before recieving more of the page, if it's a really high resolution picture, it can take forever to print. This isn't a defect at all, it's just something that you can't fix that makes this printer useless for an office. I have this printer too, I usually just go do something while it does its thing...
Aug 14, 2007 | HP PSC 1350 All-In-One Thermal Printer
Hp LaserJet 5 si
Check the print processor settings in the advanced tab of the printer properties. This should be set to Winprint, and not anything else.
May 01, 2007 | HP LaserJet 5si Printer
HP Deskjet F4180 All In One Inkjet Printer Cb584a Logo
60 people viewed this question
Seeker5211
Seeker5211
