Question about E-Machines T5212 PC Desktop
Can't get both 1 GB PC4200 ram cards to work!
Why does the pc only recognize 1 ram chip at a time? Both slots work just fine. I purchased the exact same two cards specifically for this model, T5212. It will only read one at a time. It works if I use a 1GB plus a 512MB, but not both 1 GB's.
  • ibeanoid Apr 13, 2009
    I have the same problem. I can not check the cmos because it will not even post with the 2 gb in it. It will post just fine with 1gb and 512mb installed but cmos only shows the 1gb. it has got me stumped.
    New Friend:
  • 111 Answers
Please check the CMOS setting.
nuwan.
Posted on Jan 13, 2009
PC won;t boot after memory upgrade
your comp can only handle so much ram,you also need to use the same ram,check how much ram it recognizes with only two,then 3,then 4,64 bit comps only recognize 4 gb,32 bit recognizes any gb ram.
May 22, 2015 | Computers & Internet
MSI motherboard - RC410M MS7173. I had 1 memory card of 1GB - Ceon DD2 533 CL4 I bought the exact same one again, so I would have 2GBs. The board couldn't recognize the 2 cards now. The board suppose to...
could be defective board with broken contact try switch 1gb ram chip from one slot to other see if it work in both if not you got your problem also switch the testing 1gb ram chip with other 1gb chip
Mar 02, 2011 | MSI RC410M-L Motherboard
I installed 5G memory cards to my Gateway GT5238 PC, 1024 MB DDR2, Intel core 2 Duo E6300, 9-in-1 memory card reader, Non EEC, 4 slots, max memory 8192MB (8GB), PC2-6400, 8500, 5300, RAM DDR2. It had 1G to...
  • You Gateway only supports up to 8 GB. memory. Hence it will not see your 5 GB. dimms
  • tops: 8129 MB (8 GB.). 4- 2GB. Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
  • Specs:
  • Installed: 1024 MB DDR2 (PC4200), 533 MHz memory (two 512 MB modules)
  • Expandable to: 8 GB (4 memory slots)
  • How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    Dec 02, 2010 | Gateway Computers & Internet
    Dell M60 only recognizes 1GB of ram; used to see 2GB.
    Is the memory the same size ?and belive it or not some machines don't reconize ram even thought it is installed ,if it is running good and your os reads the ram
    don't worry about it if not let me know
    Dec 24, 2009 | Dell Precision M60 Notebook
    hello there do you know if this is dram or sram athat u had and are trying to install
    Feb 21, 2009 | E-Machines T5212 PC Desktop
    I have installed one 1gb chip into my emachines t5082 computer and it worked fine. So I got another and removed the original 512 MB chip from it and it won't recognize the second 1gb chip.
    I'm assuming that your 2nd DIMM is the same type and speed as the 1st one you put in. If you are not sure, check and make sure that it is DDR2, 533MHz, PC4200.
    If they are not the same, that is most likely the problem.
    If both DIMM's are the same, remove them both and then put one of them back into DDR2 Slot 1. Start your computer and see if the computer recognizes the memory. Remove it and try the other DIMM in the same DDR2 Slot 1.
    If both work OK, the problem is on your mainboard.
    Dec 13, 2008 | E-Machines T5082 PC Desktop
    Medion ram upgrade
    I'm not a guru, but your predicament is pretty simple.
    Depending on your OS (XP 32 bit, XP 64 bit, Vista), the OS will be able to recognize a certain amount of RAM. XP 64 Bit will be able to recognize up to 6GB of RAM. Vista, I have no Idea. 32 Bit, what you're seeing right now.
    Sorry for wasting a bit of money on that last stick.
    Nov 30, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
    Problem installing ram
    You have the wrong memory chip. The beep code you hear indicates that there is no memory or incompatible memory. The memory you need is PC4200, Which is a 533mhz chip. Memory has a frequency rating that is matched to the processor and motherboard. Not just any DDR 200 pin memory that fits will work, the frequency has to match or it won't work. The new chip should be labeled, make sure it reads PC4200 or 533mhz, if it reads anything else it's the wrong chip. If it is the right frequency chip, then you may have a bad memory slot, the chip is bad, or mislabeled. Here's a link to a memory configurator that gives the memory specs for your machine.
    http://patriotmem.com/configurator/modelp.jsp
    Jul 31, 2008 | IBM ThinkPad R52 Notebook
    RAM NOT DETECTING
    I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
    Jun 25, 2008 | Intel D102GGC2 Motherboard
    E-Machines T5212 PC Desktop Logo
    203 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
