Question about Exercise & Fitness
Belt shuts off when you start running
Shuts off
    Top Expert:
  • 12,223 Answers
1)LUBE the deck belt inmediately
2)Lube the rollers bearings
3)Test the drive belt motor
4)Test the input voltage motor, if there are the motor need repair, see my personal TIPS for motor help
5)Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Belt shuts off when you start running - 12_10_2012_9_40_57_pm.gif12_10_2012_9_41_28_pm.gif
Posted on Dec 10, 2012
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
01 focus ztec..battery light comes on car runs the runs poorly then shuts off..let cool will start and run again for a while the repeats!
have you checked the fan/ serpentine belt to make sure that it isn't broke? if this just started happening, it is most likely the belt ( altenator and water pump run off the same belt)
Mar 04, 2011 | 2001 Ford Focus
Belt stops after 2 seconds
If the machine starts and tries to go full speed, the motor controller is defective.
Remove the cover. Under the cover is a tech sheet. The tech sheet will explain what the red LEDs' flashes mean.
I suspect you are experiencing an over current shutdown. The controller senses too much current and shuts down b4 causing damage.
Remove the drive belt and run the machine. It will run this way no problems. If it still shuts down, I would suspect the motor.
If it runs ok, you might want to loosen the walking belt and reinstall the drive belt and retest. A walking belt that is too tight will cause an over current shutdown.
Disconnect the motor (1 wire, either black or red) and start the machine. The relay will clik on. If it remains on, then the controller is probably OK. The motor is defective.if the controller cliks on then off again, the controller is defective..
Dec 14, 2010 | Proform 775 Crosstrainer Treadmill - Free...
My dryer was making a loud squeeking noise while drying, now it won't start, I can hear it trying purring but than it does not start, help!
if you can hear the motor running,and if this unit does not have a belt shut off switch,the motor will run even if the belt is broken,the squeaking noise earlier was probably the belt starting to slip on the drum,replace the belt and drum glides when repairing,they are relatively inexpensive and as long as its torn down replace these too
Sep 15, 2010 | GE DCSR483EA Electric Dryer
Can walk on treadmill but soon as i start to run it stops
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current limiting curcuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 20, 2010 | Reebok Vista Treadmill - RBTL13305
1997 montero sport 3000 24valve v6
The most likely senario is that the water pump went bad which caused the overheating in the first place. Then after the engine shut down, the water pump seized up. When the engine was restarted, the timing belt started to smoke because the water pump, which runs off the timing belt, was not turning. Since the engine overheated to the point of shutting down, blown head gaskets are a possibility. Put a new timing belt and water pump on it and start it up. If it runs OK, you're good to go.
Jul 26, 2008 | Mitsubishi Montero Sport Cars & Trucks
Exercise & Fitness Logo
37 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
