Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony kv-21cl10E Starting within green screen with light green diagonals - after 2-3 seconds almost normally. slashing dark shadows after white symbols in TV-mode No Problems on teletext
    New Friend:
    Problem Solver:
  • 9 Answers
Check the color drive, and resistors that change value or open, check also the connections
Posted on Sep 22, 2013
  • shem bala-oy Sep 22, 2013
    check the color drive, and resistors that change value or open, check also the connections
techman
  • 3130 Answers
SOURCE: SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Posted on Mar 25, 2006
  • 124 Answers
SOURCE: sony kv-32xbr400
Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
Posted on Mar 27, 2006
premtech
  • 934 Answers
SOURCE: tv problems
It's called a loss of vertical deflection. In this particular model your set uses a TDA8172 for a vertical Ic, at board position Ic561.
Replacing that and check or replace the feed cap out in front as needed should restore full deflection. It's not an expensive fix for a qualified shop either.. But my advice is take it into them and save the pu/del charges. And call around to see if they have the Ic on-hand and about how much it will be to replace it before choosing the shop to take it to..
Let me know how it goes!
Bill
Posted on Nov 22, 2007
SOURCE: blinking screen
My Sont Trinitrtron is flashing off and on.
Posted on Jan 26, 2009
  • 8457 Answers
SOURCE: Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Posted on Dec 19, 2009
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
May 13, 2009 | Sony Televison & Video
Sony Trinitron picture turning green hues
Nowadays CRT's do not have good quality shadow masks anymore. After heating up a little they can give a so called "blooming" effect giving a blue an yellow leaf effect large over the screen. Reason nonparallelity in deformation of the shadow mask.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Red screen in mysims pc game
Try updating your Video Card Drivers, and restarting your computer.
If that doesn't work, try reinstalling Sims (1 or 2)
Dec 29, 2008 | Video Game Consoles & Games
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green circle on the screen when I turn off TV
there is something really something wrong with your tv.try to reheat the main board.
Oct 30, 2007 | Sony KV-27FS13 27" TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
