Question about Sewing Machines
Brother pr-600 screen not responding
So I was sewing with my Brother PR-600 embroidery machine and it locked up in the middle of a project. The touchscreen was completely unresponsive. I shut off the machine for a few minutes and turned it back on. The screen shows normal start up screens and looks like its gonna work just fine, but when I touch the screen nothing happens. I have pressed all over the screen and I get no response whatsoever from the machine. I have tried turning on and off multiple times, I even left it off over night and still nothing. Any ideas on how to fix this? Thanks
  • Sewing Machines Master
  • 1,564 Answers
See if you can discover how to reset the machine. Typically it is a combination of buttons pressed either simultaneously or in order as the machine is starting.
Posted on Dec 10, 2012
bargainbox
  • 1388 Answers
SOURCE: touch screen not responsive
You need to re-align the touch screen using the following routine:
Accessing Alignment Mode:
Then you will see a text message something like
"Press + to align"
STOP
Don't touch the "+" in the text message !!!!!
The one you want will be elsewhere on the screen and all on it's own, with no text around it.
Using the non pointed end of a needle, or the spare spool pin (nothing sharp) gently but as accurately as you can, touch the centre of the +
The + will move to several more locations as it organises the height, width and orientation you give by touching the centre of the + as it appears each time.
When it is finished, turn machine off, then on as normal.
If this does not correct the issue, it may well be something else, so please, if you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 18, 2008
SOURCE: Brother PR-600...does anyone know if it's a major
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Posted on Mar 01, 2010
chris592
  • 86 Answers
SOURCE: I have a Brother PC-8200 embroidery sewing
That's a tough call, parts can be pretty high to fix a machine. Have looked around to price out a new embroidery machine, Janome makes some very nice one in that price range. I'd try ebay there is one which is missing the foot control and hoops for $250.00 just search Brother Pacesetter PC-8200 this may be the ticket you already have the foot control and hoops.
Best of luck
Posted on Feb 11, 2011
  • 11800 Answers
SOURCE: My artista 180 is 10 years old and to date has
This isn't a software issue: the embroidery mechanism has failed due to normal age related wear, it's no longer detected by the machine and this is why you now only get the sewing screen.
The only way to fix that is to replace the entire embroidery mechanism and for that the unit must be completely dismantled . Since this would cost more than the the price of a new machine it's simply not worth it to have it repaired. Use it as is or get a new one.
Posted on Jul 01, 2011
SOURCE: Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Posted on Aug 14, 2011
My singer pr 600 it shut down in the middle of sewing there is a light flashing on the needle bar but the led screen is blank and seems to have no power
I would contact Singer. Online. You may have an electrical short, in the machine. Singer Hates machines with such problems, and will work with you to fix or replace it!
Jan 22, 2018 | Singer Sewing Machines
How do i repair X-Axis home position error for pr 600II
If the machine's embroidery arms have been moved under force when the machine's power is on, you may need to have the machine tune up and reset to true center. I would suggest taking it to a authorized repair shop for a good cleaning and service. In most cases for what you paid for the machine, there is included service that can come with the purchase of the machine, or in the least, a discount on mechanical services and repairs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Mar 02, 2015 | Sewing Machines
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
My pr 600 freezes
You might have Thread particles build up. Puchase canned Air for electronis and use it on a regular basic to clean your bobbin case area. Also when you change threads color always clip your thread near the spool and pull your thread out from the bottom near your needle. When you pull your thread through the top little pieces of the thread break of and fall into the chamber of your embroidery machine .
Mar 05, 2014 | Bernina Bernette Deco 600
My machine seems to be froze up. The part that comes out of the machine( that the pressure foot is attached to) will not move. My machine is fairly knew and under warranty. I have not tried to work on...
here are 2 dealer of brothers that may be able to help
WOODBURN SEW & VAC CENTER INC.
1002 N PACIFIC HWY
WOODBURN, OR 97071
503-981-6921
Click here for Map
ACE SEWING & VACUUM
2414 PORTLAND RD. STE 1
NEWBERG, OR 97132
503-538-1177
Click here for Map
* PR Series Authorized
Feb 11, 2011 | Brother CE5000 Computerized Sewing Machine
Black line down middle of LCD screen Brother
the screen will have to be replaced is it under warranty?
Aug 27, 2010 | Brother InnovIs 4000D Computerized Sewing...
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
Nov 04, 2009 | Brother Sewing Machines
I am wanting a monogramming or embroidery machine for my home business. I am looking at a Meistergram 900xl. Does anyone know anything about this machine? I know they only make embroidery machines now so I...
I would recommend looking at the PR-620 its a single head emb only machine with 6 needles and is made by brother, you can do hats and just about every thing including momgramming plus they have a great rebate going on right now
Jul 15, 2009 | Brother CS6000i Computerized Sewing...
Needle securing screw
My PR600II error message main rotate error. what can i do to fix it
Nov 29, 2007 | Brother Sewing Machines
Sewing Machines Logo
949 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
